02-13-2020, 22:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | huawei p30 pro VOG-AL10 huawei id? He downloaded the firmware to download the file for downgrade and remove the Huewei account, but since I see 3 folders with several application files, I need the necessary instructions to avoid mistakes. If you have a clearer manual than the one that is available or any video available with the process, I appreciate it, which I don't want to make a mistake. |
02-15-2020, 16:16 | #5 (permalink) |
Freak Poster Join Date: Feb 2005 Location: algiers algeria Age: 51
Member: 115573 Status: Offline Thanks Meter: 102 | vog-al10 id bypass Checking fastboot device.....OK Reading info.....OK Device Model: VOG-AL10 Device Firmware: :VOG-AL10 10.0.0.188(C00E85R1P8) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: F405A7ACC788DA00 Elapsed time 00:00 -- Version 1.9.3 thx |
02-17-2020, 13:01 | #7 (permalink) | |
Member: 115573 Status: Offline Thanks Meter: 102 | Quote:
i used VOG-AL00 for my VOG-AL10 successfully downgraded after i use https://easy-firmware.com/index.php?...file&id=179411 with useful guide in. for finish. just corret guide in folder "STEP3" is atached | |
02-18-2020, 10:46 | #8 (permalink) | |
Freak Poster Join Date: May 2015 Location: Chittagong
Member: 2397029 Status: Offline Thanks Meter: 52 | Quote:
03-13-2020, 09:56 | #9 (permalink) |
Junior Member Join Date: Aug 2015 Location: Romania
Member: 2438061 Status: Offline Sonork: 1668258:videle.gsm Thanks Meter: 4 | hy, i can remove huawei id ? i tried to write this firmware and it failed https://easy-firmware.com/index.php?...file&id=179514 Checking fastboot device.....OK Reading info.....OK Device Model: VOG-AL00 Device Firmware: :VOG-AL00 10.0.0.188(C00E85R2P8) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: 488E840D14D08368 Elapsed time 00:00 -- Version 1.9.6 |
03-26-2020, 08:35 | #11 (permalink) |
Member: 2438061 Status: Offline Sonork: 1668258:videle.gsm Thanks Meter: 4 | hy, solution for huawei id remove? Checking fastboot device.....OK Reading info.....OK Device Model: VOG-AL00 Device Firmware: :VOG-AL00 10.0.0.188(C00E85R2P8) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Operation {Read info} ID: 488E840D14D08368 Elapsed time 00:00 -- Version 1.9.6 |
03-26-2020, 10:26 | #12 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
today just paid solution Its possible . but not free ( | |
