Old 10-04-2018, 01:05   #1 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 182
Huawei rne-l21 frp fail HELP
Is this HUAWEI RNE-L21 .SW: :RNE-L21 8.0.0.334(C432) supported by siGmakey?
Old 10-04-2018, 06:32   #2 (permalink)
Mohammed Aamri's Avatar
Member: 2536614
Thanks Meter: 2,785
Did you try to use MTP offline FRP remove method.
BR,
Mohammed Aamri
The Following User Says Thank You to Mohammed Aamri For This Useful Post:
Old 10-04-2018, 07:40   #3 (permalink)
Member: 2217500
Sonork: 100.1597179
Thanks Meter: 326
bypass is the solution...r there is fix rom for bypass...otherwise many devices has failed to remove frp for this model....
The Following User Says Thank You to ximasim For This Useful Post:
Old 10-04-2018, 08:09   #4 (permalink)
Member: 2536614
Thanks Meter: 2,785
If the phone have new security then it's not supported with EFT Dongle ,any way Try to use this manual method :
https://easy-firmware.com/index.php?...rticle&id=6860
BR,
Mohammed Aamri
Old 12-02-2018, 13:11   #5 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
THIS IS YOUR SOULOUTION TO BYPASS IT BRO
https://*********/mtf7VCrrBBw&fs=1" width="644" height="390">https://*********/mtf7VCrrBBw&fs=1" />https://*********/mtf7VCrrBBw">http://www.youtube.com/watch?v=https://*********/mtf7VCrrBBw
Old 12-02-2018, 13:46   #6 (permalink)
Thanks Meter: 21,200
link edited
http://www.youtube.com/watch?v=mtf7VCrrBBw
Old 12-02-2018, 13:59   #7 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Originally Posted by easy-team View Post
HUAWEI RNE-L21 .SW: :RNE-L21 8.0.0.334(C432 App not install in this ver
Old 12-02-2018, 14:52   #8 (permalink)
Member: 2794819
Thanks Meter: 6
app not installed in this version
Old 12-02-2018, 15:50   #9 (permalink)
not working on latest security patch
Old 12-02-2018, 16:39   #10 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
C185 App Not Install
Old 12-02-2018, 16:43   #11 (permalink)
Old 12-02-2018, 19:20   #12 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
This firmware is the RNE-L21 8.0.0.33
Sent from my iPhone using Tapatalk
Old 12-03-2018, 03:06   #13 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
the security path October 01 2018 can not install app
have solution bypass or not?
Old 12-03-2018, 05:20   #14 (permalink)
downgrade. and try agein.
Page generated in 0.23749 seconds with 8 queries
