05-04-2018, 01:30 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | J701M BIT3 error help I need your help please, I can not do Root Yesterday I could do Root without problems, the same model, the same security and even the same software, but today I get the following errors: 1) Root [IMG][/IMG] [IMG][/IMG] then doing a little research on this problem and depending on what you get, it's an RMM block, then use the option: Make Recovery Disable Rmm State but it still gives the same error: 2) Rocovery [IMG][/IMG] [IMG][/IMG] please any help or guide, I would appreciate it |
05-04-2018, 20:39 | #3 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | You have to flash latest firmware and wait 7 days then the RMM State will disappear , only then you can flash recovery to disable rmm state and root ! |
05-15-2018, 15:34 | #7 (permalink) | |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | Quote:
the cell phone is already active for 193 hours. Now if I should not have trouble doing Root? And if he keeps giving me the same error as at the beginning, what could he do? [IMG][/IMG] I await your response to be able to proceed | |
05-15-2018, 18:54 | #9 (permalink) |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | there is the screenshot, but I do not see any change and still giving the same error What solution can you give me? [IMG] delete account[/IMG] |
05-16-2018, 17:36 | #11 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Your device mode is normal which can allow you to flash anu custom image Its a starnge issue you are having But not for this model where i once had binary -1 😂 So try the following flash full combination then full flash To see the result if RMM state is reseted to show its real state You can also try unlock in combination mode |
05-17-2018, 15:07 | #12 (permalink) |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | step combination install kingroot.apk but it does not leave root I just need Root to be able to repair imei I already leave 7 days as recommended, but it still fails |
05-22-2018, 18:08 | #15 (permalink) |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | thanks for answering 1) rmm state Normal as at the beginning in the 1st post 2) UP time was the same J701M, before it was 193 hours, but as you said Give me screen shot for download mod, now the counter started again from 0 3) even though I spend 193 hours, same problem and I do not understand why ... I need an explanation 4) I have the cell phone from May 3 to May 22 and I still have the problem |
