GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   EFT Dongle (https://forum.gsmhosting.com/vbb/f1014/)
-   -   WAS-LX1 screen lock (https://forum.gsmhosting.com/vbb/f1014/lx1-screen-lock-2721656/)
Miluk 11-06-2019 18:25
WAS-LX1 screen lock
Hi
Is possible to add more time for patching operation?
All working until pathing ok just still is failed because phone is connecting to adb in 90sec and timer is only for 60sec.
Checking fastboot device.....OK
Reading info.....OK
Device Model: WAS-LX1
Device Serial: PMxxxxxxxxx
Device IMEI: 86xxxxxxxxxxxx
Device IMEI2: 86xxxxxxxxxxxx
Device Firmware: :WAS-LX1 8.0.0.376(C738)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Processing file 1.....OK
Processing file 2.....OK
Switching to ADB mode.....OK
Waiting for device.....OK
Rebooting.....OK
Patching.....Failed: Device not found
Operation {Reset ScreenLock} ID: FDC91DC0F566882B1A4BAC12CD5D12E9
Elapsed time 02:13 -- Version 1.7.2
Any help would be useful
easy-team 11-08-2019 00:34
what was the device condition that moment ? did you try again ?
Miluk 11-08-2019 14:01
In this moment phone power on, is accessible to settings but on main screen icons missing.
Miluk 11-09-2019 23:36
Any idea?
It may support to propose a solution or to add more time to the each stages?
Wysłane z mojego Pixel 3 przy użyciu Tapatalka
zexos 11-11-2019 15:09
i have the same problem at stage for
- When device boot Do the following in ADB auth dialog:
- Check 'Always allow from this computer' option
- Press on 'OK'
- WARNING: Do not touch anything else
adb not active must manual active it
and at satge final no adb will active
easy-team 11-11-2019 19:00
- Press on 'OK'
So you solved your problem that way ?
easy-team 11-11-2019 23:38
Problem mainly caused by not installing drivers mentioned in sticky thread
http://forum.gsmhosting.com/vbb/f101...emove-2705090/
zexos 11-12-2019 09:20
well just have setting and cant restore lock screen
zexos 11-12-2019 09:26
Reading info.....OK
Device Model: WAS-LX1A
Device Serial: 2XJ7N17408000573
Device IMEI: 863094032833583
Device IMEI2: 863094032863598
Device Firmware: :WAS-LX1A 8.0.0.371(C185)
Device Lock: locked
Reading data.....OK
Rebooting.....OK
Patching.....Failed: can not patch data1
Operation {Reset ScreenLock} ID: 3FBB88BEE574A94A1840BB691637E230
Elapsed time 02:28 -- Version 1.7.2
need to restore lock screen
easy-team 11-12-2019 11:45
When the dongle get device in recovery mode you reboot manully and you didnt let dongle complete the job , we said hundred of times , dont touch the device until job done .
easy-team 11-12-2019 11:49
I STILL HAVE THE SOLUTION FOR SUCH USER MISBEHAVING , Contact me via official page PM and i have to fix it via team viewer , because it needs development skills .
pyzdraaaa 11-12-2019 16:18
- Press on 'OK'
WAS-LX1C432B390
pyzdraaaa 11-13-2019 15:28
on windows 7 for it worked on win 10 missing the following in ADB auth dialog:
Screen lock removed
Page generated in 0.16869 seconds with 6 queries
