12-21-2018, 15:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2016
Member: 2652531 Status: Offline Thanks Meter: 66 | make root for LG in fastboot by EFT dongle easy and simple hello brothers Today we root LG phone Tp 450 by EFT dongle everything is easy and simple 1 confirms the absence of Root We put the phone in the Download mode then 1 Select the COM via scan port 2 select only the boot file 3 Learn to read the file 4 Start the process 5 Successfully saved We make the root file 1 Connect any phone to the adb mode 2 make Root file from the file boot.img and save it We do unlock the manufacturer lock and activate adb Then enter the phone into the Fastboot mode As the picture Press the shift in the keyboard with the right mouse button and then choose open commond. In the attachment adb file https://androidfilehost.com/?fid=24588212152304238 Then open the bootloader by issue this command [fastboot oem unlock] note: this will wipe your data] After that, we will flash the file boot.EFTPRO The phone asks for the power button to continue. Do not worry |
The Following 20 Users Say Thank You to proglak For This Useful Post: |
12-21-2018, 15:42 | #2 (permalink) |
No Life Poster Join Date: Feb 2016 Location: Europe
Member: 2536614 Status: Offline Thanks Meter: 2,785 | Great ! thanks for this useful report, thread sticky . BR, Mohammed Aamri Last edited by Mohammed Aamri; 12-22-2018 at 11:40. |
The Following 3 Users Say Thank You to Mohammed Aamri For This Useful Post: |
12-21-2018, 18:55 | #4 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,270 | Thanx sir , much appreciated hard work , keep it up ! |
The Following 4 Users Say Thank You to easy-team For This Useful Post: |
02-09-2019, 21:02 | #10 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | i used same methode but root permission fail LG h901 7.0 not root with this methode here is logs EASY-TEAM Waiting For Android Device.......OK Reading Device Info.......OK Product: LGE Device Chipset: Qualcomm Device Model: LG-H901 Device Serial: LGH901addc475a Android Version: 7.0 Android SDK: 24 Architecture: arm64-v8a Free space in system disk: 642M Phone Mode: Normal Mode Checking Root Permission.......Fail |
02-10-2019, 11:10 | #11 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Quote:
I Need LG H901 Root File EFT Team Next Update Fix | |
