10-11-2018, 23:30
#1 (permalink)
Member: 2669781
Thanks Meter: 1,839 | N910V__{Unlock BootLoader, Perm-Root, Add AR-FR}__successfully done via EFT Hi, i know the procedure has been already introduced, but wishing to draw the steps clearer and easier to the users, since many are those who still complain about failing to root/add languages to this device......thanks Full logs of the operation/
1_First Write the following firmware/ 2-Download and install KingoRoot PC version, get temp root access, do not reboot device, since the device will lose root at the first reboot. Link:https://www.kingoapp.com/
3-Connect Device to EFT, hit connect, go android model>>unlock bootloader
Device will then reboot, wait until EFT says: OK
4-Check your Download mode, you'll See mode=Developer, then tun on the phone
5-Extract boot.img from the same firmware, using Zip, make Root kernel, then simply flash the .EFT file. You're all set, you have permanent root privileges. Quote: Unlocking the Bootloader/ Flashing Boot.eftpro/Rooting/ Translating to Ar and Fr Code: EASY-TEAM
Waiting For Android Device.......OK
Reading Device Info.......OK
Product: samsung
Device Chipset: qcom
Device Model: SM-N910V
Device Serial: 00000000000
Android Version: 5.0.1
Android SDK: 21
Architecture: armeabi-v7a
Free space in system disk: 381.3M
Phone Mode: Normal Mode
Checking Root Permission.......OK
Preparing device.......OK
Wait fixing........OK
First Install........OK
backup: VRSetupWizardStub.apk........OK
backup: VoiceNote4T.apk........OK
backup: TouchWizHome.apk........OK
backup: TeleService.apk........OK
backup: SystemUI.apk........OK
backup: S-Voice_Android_phone.apk........OK
backup: SecVideoPlayer.apk........OK
backup: SecVideo.apk........OK
backup: SecSettings.apk........OK
backup: SecMyFiles2014.apk........OK
backup: SecMms_Candy.apk........OK
backup: SecGallery2014L.apk........OK
backup: SecContacts_Note_USA.apk........OK
backup: SamsungMusic_20.apk........OK
backup: EasyLauncher2.apk........OK
backup: framework-res.apk........OK
backup: CSCAppResource.apk........OK
backup: VisualVoiceMail.apk........OK
backup: VideoEditor_Lite_T.apk........OK
backup: SPlanner_OS_UPG.apk........OK
backup: SecExchange.apk........OK
backup: SecEmail_K.apk........OK
backup: SecCalculator2.apk........OK
backup: SBrowserTry.apk........OK
backup: SBrowser.apk........OK
backup: SamsungSetupWizard.apk........OK
backup: SamsungMusicRemoteController.apk........OK
backup: SamsungCameraFilter.apk........OK
backup: SamsungCamera3.apk........OK
backup: PackageInstaller.apk........OK
backup: LegacyInCallUI.apk........OK
backup: EmergencyLauncher.apk........OK
backup: EasySettings.apk........OK
backup: DocumentsUI.apk........OK
backup: ClockPackage_Osup_T.apk........OK
Translating: VRSetupWizardStub.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: VoiceNote4T.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: TouchWizHome.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: TeleService.apk.......OK
Translating: SystemUI.apk.......OK
Translating: S-Voice_Android_phone.apk......:.Skip. App contains language values-fr
EFT Dongel Try to fix .. (1)
Fail!!...Use other apktool.jar
Translating: SecVideoPlayer.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SecVideo.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SecSettings.apk.......OK
Translating: SecMyFiles2014.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SecMms_Candy.apk.......OK
Translating: SecGallery2014L.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SecContacts_Note_USA.apk......:.Skip. App contains language values-fr..OK
Translating: SamsungMusic_20.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: EasyLauncher2.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: framework-res.apk.......OK
Translating: CSCAppResource.apk......:.Skip. App contains language values-fr..OK
Translating: VisualVoiceMail.apk.......OK
Translating: VideoEditor_Lite_T.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SPlanner_OS_UPG.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SecExchange.apk.......OK
Translating: SecEmail_K.apk.......OK
Translating: SecCalculator2.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SBrowserTry.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SBrowser.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SamsungSetupWizard.apk.......OK
Translating: SamsungMusicRemoteController.apk.......OK
Translating: SamsungCameraFilter.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: SamsungCamera3.apk.......OK
Translating: PackageInstaller.apk.......OK
Translating: LegacyInCallUI.apk.....
Translating: EmergencyLauncher.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Translating: EasySettings.apk.......OK
Translating: DocumentsUI.apk.......OK
Translating: ClockPackage_Osup_T.apk......:.Skip. App contains language values-fr.:.Skip. App contains language values-ar.:.Skip. App contains language
Calculating size.....
Stock total Size: 130.507
Mod total Size: 226.356
Mod - stock =95.8484
Free Size in System: 661.3
Send to mobile TeleService.apk.......Success
Send to mobile SystemUI.apk.......Success
Send to mobile S-Voice_Android_phone.apk.......Fail
Send to mobile SecSettings.apk.......Success
Send to mobile SecMms_Candy.apk.......Success
Send to mobile SecContacts_Note_USA.apk.......Success
Send to mobile framework-res.apk.....
Send to mobile CSCAppResource.apk.......Success
Send to mobile VisualVoiceMail.apk.......Success
Send to mobile SecExchange.apk.......Success
Send to mobile SecEmail_K.apk.......Success
Send to mobile SamsungSetupWizard.apk.......Success
Send to mobile SamsungMusicRemoteController.apk.......Success
Send to mobile SamsungCamera3.apk.......Success
Send to mobile PackageInstaller.apk.......Success
Send to mobile LegacyInCallUI.apk.......Fail
Send to mobile EasySettings.apk.......Success
Send to mobile DocumentsUI.apk.......Success
send (framework-res.apk) .......Success
Finished
Translated | |
