Old 06-25-2018, 19:07   #1 (permalink)
Member: 2668830
Thanks Meter: 15
Exclamation RMM State: Normal J530G
Hello, what would I have to do to remove the RMM and be able to root without any problem?
MODEL: SM-J530G
BIT: 2
RMM: NORMAL
FRP: OFF
OEM: OFF
I read that I have to wait 170 hours to be able to flash, it's almost time out, it only needs 23 hours, what file is flashing?
Old 06-25-2018, 21:56   #2 (permalink)
Member: 2202707
Sonork: Tomelich
Thanks Meter: 141
I think that to this day they do not give a solution
J701M BIT3 error help
Old 06-25-2018, 22:20   #3 (permalink)
Thanks Meter: 10,257
Extract boot.img from same firmware as in device then navigate to Make root section and make root kernel (inject rmm state)
The Following User Says Thank You to easy-team For This Useful Post:
Old 04-11-2019, 19:19   #4 (permalink)
Member: 2317699
Sonork: +51-991259299
How boot is extracted, and with what tool.
Old 04-11-2019, 20:01   #5 (permalink)
sajidi1984's Avatar
Member: 2778467
Thanks Meter: 73
this is EFT section obviously with EFT.....!!!!!!!
The Following User Says Thank You to sajidi1984 For This Useful Post:
Old 04-11-2019, 22:05   #6 (permalink)
watch this carefully ...
http://www.youtube.com/watch?v=92E97JgO0Rw
Old 04-15-2019, 23:49   #7 (permalink)
Member: 1434691
I did not succeed with j701m android 7.0, I did the whole procedure and when I reconnected it in root permissions I got an error ... my question is if it supports all the models, this method or if there is a list of models that support, from now on thanks
Old 04-16-2019, 00:28   #8 (permalink)
Member: 1552419
Thanks Meter: 9
bro
in download mode
open chimera tool after FRP BYPASS
when complete DOWNLOAD MODE AGAINT
RMM IS OFF but remove 100%, flash twrp and flash
https://androidfilehost.com/?fid=11410963190603859122
ready 100% remove
Old 04-16-2019, 10:10   #9 (permalink)
We will add RMM bypass ASAP .
Page generated in 0.13750 seconds with 7 queries
