Old 10-18-2019, 01:31   #1 (permalink)
Thanks Meter: 14,135
Root procedure for latest Samsung devices with base Android version 9.0
Hello everyone ,
It is very important to follow this procedure exactly and dont bypass any step when you root Samsung device :
A10-20-30-50-70-Note 10 -Note10+ and any device comes with base android version 9.0 ...
1- Make Root kernel .
2- Unlock bootloader
3- Make Sure RMM or KG is stopped .
How to stop RMM or KG in most devices .
Flash full stock rom , once device bootup choose language and connect to wifi then continue with device setup until you reach the desktop then enable Dev mode and wait til OEM show up , enable it and you are done
4- Reboot to recovery
5- Do factory Reset
6- Reboot to download mode
7- Press & Hold Volume up and start flashing the root kernel , release the Volume up button when the first logo appears
8- Now your device is rooted.
9- Next time you want to get root access just turn off your device press volume up and start device .
Best Regards
Easy Team
The Following 12 Users Say Thank You to easy-team For This Useful Post:
Old 10-18-2019, 08:03   #2 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 27
Analyzing file [C:/Users/feder/Downloads/Compressed/A205FXXU2ASE6 A205FOLM2ASE6 (XME) Firmware 4 Files 9 Halabtech/boot.img.lz4].....OK
Decompressing LZ4.....OK
Checking output file.....OK
File to process [C:/Program Files/EFT Dongle/boot.img]
Unpacking image.....Failed
Operation ID: DCCDEF2687BFFB4949A7D226FEE9E1B8
Elapsed time 00:09 -- Version 1.6.4
Old 10-18-2019, 09:14   #3 (permalink)
Member: 1284175
Sonork: aa
mtk qualcomm frp tool add
Old 10-18-2019, 12:33   #4 (permalink)
Move AP file to desktop and choose it as it is , Dont extract boot manually .
The Following User Says Thank You to easy-team For This Useful Post:
Old 10-18-2019, 13:03   #5 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 27
Analyzing file [C:/Users/feder/Desktop/AP_A205FXXU2ASE6_CL15936623_QB23927805_REV00_user_ low_ship_meta_OS9.tar.md5].....OK
Extracting files.....OK
File to process [C:/Program Files/EFT Dongle/recovery.img]
Unpacking image.....OK
Checking ramdisk status.....OK
Patching ramdisk.....OK
Patching dm-verity flags.....OK
Patching protections.....OK
Repacking image.....OK
Repacking second image.....OK
Rooted image saved to [C:/Users/feder/Desktop/RootedBoot.oEFT]
Elapsed time 01:29 -- Version 1.6.4
Create Done but After write mobile Restart problum samsung logo
Old 10-18-2019, 23:43   #6 (permalink)
aymandh4's Avatar
Member: 2529545
Thanks Meter: 55
I have A705FN U1 FRP OFF OEM OFF KG OFF.. BUT AFTER FLASH ROOT NOT ROOTED
Envoyé de mon SM-J600F en utilisant Tapatalk
Old 10-19-2019, 03:08   #7 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,918
After write boot do hard reset phone once
Old 10-19-2019, 08:46   #8 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 27
hard reset done but set not rooted show
Old 10-19-2019, 10:35   #9 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 27
Root done but not Root
Status not rooted
Old 10-19-2019, 14:45   #10 (permalink)
you didnot do this exactly
5- Do factory Reset
Old 10-19-2019, 14:46   #11 (permalink)
if you did this
5- Do factory Reset
6- Reboot to download mode ( from recovery)
after flashing device with root , it will not ask for format .
So i said follow procedure as it is exactly
Old 10-19-2019, 15:23   #12 (permalink)
Status not rooted
Old 10-20-2019, 05:09   #13 (permalink)
Member: 2170171
Sonork: 100.1652359
Thanks Meter: 27
please sir make videos how to root A205f u2
Old 10-29-2019, 11:34   #14 (permalink)
Member: 1391134
Thanks Meter: 42
i tested this solution in a505f and a205f and a105f and m105f but dident work .
this solution not work . we need the real solution
The Following User Says Thank You to sagad For This Useful Post:
Old 11-09-2019, 09:10   #15 (permalink)
Member: 2253540
Thanks Meter: 27
The Following User Says Thank You to masumgsm For This Useful Post:
Page generated in 0.35916 seconds with 7 queries
