06-22-2018, 11:02 | #5 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,200 | As i saw your flash was not successful because you didn't select files to flash , First select files then press flash ! After flashing if situation still the same then it is EMMC failure ! |
The Following User Says Thank You to easy-team For This Useful Post: |
06-23-2018, 04:16 | #13 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Ph
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | <ID:0/018> Odin engine v(ID:3.1203).. <ID:0/018> File analysis.. <ID:0/018> SetupConnection.. <ID:0/018> Initialzation.. <ID:0/018> Get PIT for mapping.. <ID:0/018> Firmware update start.. <ID:0/018> SingleDownload. <ID:0/018> sboot.bin <ID:0/018> cm.bin <ID:0/018> boot.img <ID:0/018> recovery.img <ID:0/018> system.img <ID:0/018> cache.img <ID:0/018> hidden.img <ID:0/018> FAIL! <ID:0/018> <ID:0/018> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
06-23-2018, 08:11 | #14 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | Quote:
The Following User Says Thank You to ..::KASHIF::.. For This Useful Post: |
