11-06-2019, 18:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: PL
Member: 384541 Status: Offline Thanks Meter: 101 | WAS-LX1 screen lock Is possible to add more time for patching operation? All working until pathing ok just still is failed because phone is connecting to adb in 90sec and timer is only for 60sec. Checking fastboot device.....OK Reading info.....OK Device Model: WAS-LX1 Device Serial: PMxxxxxxxxx Device IMEI: 86xxxxxxxxxxxx Device IMEI2: 86xxxxxxxxxxxx Device Firmware: :WAS-LX1 8.0.0.376(C738) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Processing file 1.....OK Processing file 1.....OK Processing file 2.....OK Switching to ADB mode.....OK Waiting for device.....OK Rebooting.....OK Waiting for device.....OK Patching.....Failed: Device not found Operation {Reset ScreenLock} ID: FDC91DC0F566882B1A4BAC12CD5D12E9 Elapsed time 02:13 -- Version 1.7.2 Any help would be useful BR |
11-11-2019, 15:09 | #5 (permalink) |
Freak Poster Join Date: Jul 2015 Location: ir-bandarabbas
Member: 2434148 Status: Offline Thanks Meter: 18 | i have the same problem at stage for - When device boot Do the following in ADB auth dialog: - Check 'Always allow from this computer' option - Press on 'OK' - WARNING: Do not touch anything else adb not active must manual active it and at satge final no adb will active |
The Following User Says Thank You to zexos For This Useful Post: |
11-11-2019, 19:00 | #6 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,226 | Quote:
So you solved your problem that way ? | |
11-11-2019, 23:38 | #7 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,226 | Problem mainly caused by not installing drivers mentioned in sticky thread http://forum.gsmhosting.com/vbb/f101...emove-2705090/ |
11-12-2019, 09:26 | #9 (permalink) |
Member: 2434148 Status: Offline Thanks Meter: 18 | Checking fastboot device.....OK Reading info.....OK Device Model: WAS-LX1A Device Serial: 2XJ7N17408000573 Device IMEI: 863094032833583 Device IMEI2: 863094032863598 Device Firmware: :WAS-LX1A 8.0.0.371(C185) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....OK Processing file 1.....OK Processing file 1.....OK Processing file 2.....OK Switching to ADB mode.....OK Waiting for device.....OK Rebooting.....OK Waiting for device.....OK Patching.....Failed: can not patch data1 Operation {Reset ScreenLock} ID: 3FBB88BEE574A94A1840BB691637E230 Elapsed time 02:28 -- Version 1.7.2 |
11-12-2019, 11:45 | #11 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,226 | When the dongle get device in recovery mode you reboot manully and you didnt let dongle complete the job , we said hundred of times , dont touch the device until job done . |
11-12-2019, 11:49 | #12 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,226 | I STILL HAVE THE SOLUTION FOR SUCH USER MISBEHAVING , Contact me via official page PM and i have to fix it via team viewer , because it needs development skills . |
11-12-2019, 16:18 | #13 (permalink) |
Junior Member Join Date: Jul 2009 Location: POLAND
Member: 1066792 Status: Offline Sonork: Pyzia Thanks Meter: 7 | i have the same problem at stage for - When device boot Do the following in ADB auth dialog: - Check 'Always allow from this computer' option - Press on 'OK' - WARNING: Do not touch anything else adb not active must manual active it and at satge final no adb will active WAS-LX1C432B390 |
