03-17-2019, 14:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: {INDIA}
Member: 1272558 Status: Offline Sonork: 100.1669383 Thanks Meter: 317 | samsung j610f frp solution need same frp note gone how to remove frp this model try (userdata skip ) same |
05-28-2019, 00:47 | #5 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Where i Want
Member: 1699006 Status: Offline Thanks Meter: 179 | This case is very important to me, it will be appreciated if you do help me. Reason why i am trying with EFT is because phone has damaged WIFI Are you able to provide any solution ? I try Combination file and reset FRP Via ADB - Says OK but still FRP ON I try Combination activate ADB then Flash Files BL+AP+CSC Home WO Modem but ADB Will be closed. Any help considering that phone WIFI Cant be repaired. All tools that i own failed, the only hope is EFT - i can corporate in this case if you need something Thanks in Advance |
05-28-2019, 11:10 | #8 (permalink) | |
Member: 1699006 Status: Offline Thanks Meter: 179 | Quote:
Samsung will not automatically use internet WO APN configured At last in mine country, i try that before i ask for Help Any other solution ? | |
05-28-2019, 18:15 | #9 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | flash combination after that flash from stock room sytem,recovery,boot,sboot phone will boot in menue enable oem put phone back to download mode after that full flash stock |
05-29-2019, 17:00 | #10 (permalink) | |
It will not work , Phone will remain on smart switch or will come with message like Security has been changed please reset to factory defaults | |
