Old 03-15-2019, 07:05   #16 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 242
i,m also searching for solution, but in mine case, when device have pattern lock too,
Originally Posted by Little_Master View Post
How about the phone with MDM lock and can not get into download mode?
any solution for those ?
NOTE FOR KIDS : don't reply saying press volume down+bixby+power key to enter download, or use 300k tool or bla bla bla.
There is a new knox security in devices which doesn' let the phone go in download mode to flash any file on it.
LITTLE MASTER
Old 04-03-2019, 13:35   #17 (permalink)
Member: 806294
Thanks Meter: 5
N950f MDM Done.
N950F 9.0 Remove mdm samsung remove knox samsung Done. With EFT Dongle
The Following User Says Thank You to SAJID338 For This Useful Post:
Old 04-03-2019, 16:02   #18 (permalink)
Thanks Meter: 11,141
Unfortunately Devices not going into Download Mode not supported by us yet .
Old 04-03-2019, 16:04   #19 (permalink)
Thanx buddy , always try to provide the procedure
The Following User Says Thank You to easy-team For This Useful Post:
Old 04-04-2019, 20:29   #20 (permalink)
littmanr's Avatar
Member: 190377
Thanks Meter: 60
Could to test this files with N9600 (Note9)???
Enviado desde mi iPhone utilizando Tapatalk
Old 04-05-2019, 07:54   #21 (permalink)
Member: 129163
Thanks Meter: 58
RMM Prenormal so cant flash boot.eftpro file
Old 04-05-2019, 08:56   #22 (permalink)
yonic69's Avatar
Member: 2590666
Thanks Meter: 83
Just leave the phone 7 days without turning off and the prenormal state will change to normal state.
Old 04-11-2019, 05:16   #23 (permalink)
Member: 2786103
Originally Posted by webzone136 View Post
10 times reset this its working without any problem you can reset with recovey and as well what else
can you update,?? mine was blocked again when i updated
Old 04-24-2019, 15:43   #24 (permalink)
Member: 5345
Thanks Meter: 29
1 select boot image and click make kernal to bypass knox you get boot file
2 select EFT file.pro then flash
3 combination file select cm.bin and flash now mdm remove
100% eft dongle make this
Thankyou
And whats Knox Warranty void ? 0x0 or 0x1 ?
Old 06-26-2019, 11:45   #25 (permalink)
Member: 92260
Thanks Meter: 788
S10 FRP + MDM + User Lock
I have an S10 which has all 3 locks on at the same time
1. FRP
2. MDM (RAC)
3. User lock
So, starting with the S10 series the MDM security locks out both download and upload modes, including the following AT commands on the USB-Modem port:
AT+FUS?
AT+SUDDLMOD=0,0
After the above commands the phone turns off trying to go into download mode but MDM prevents it. But at least they provide enough delay right after bootup and before the MDM popping up to allow quickly going into Settings > Lock Screen > Screen Lock Type > None (of course must know your lock code)
There are a bunch of other AT commands which seem to work on the USB-Modem port, but none of them are too useful to unlock MDM:
AT+AIRPLANEVALUE?
AT+BATGETLEVEL?
AT+CIMI
AT+DEVCONINFO - Long info
AT+DLMODE - ??
AT+FACTORST=0,0 - Factory reset
AT+FUS? - DL mode
AT+GSN - IMEI
AT+IMEINUM
AT+SERIALNO
AT+SIZECHECK - Storage info
AT+SIZECHECK=1,0 - Storage info
AT+SUDDLMOD=0,0
AT+SVCIFPGM=1,1 - Short Info
AT+SWDLMODE - ??
AT+SWVER=1,0 - DL mode
AT+SWVERSION=1,0
AT+SYSSCOPE=1,0
AT+WPROTECT=1,0
The only mode that works is recovery (unfortunately not much can be done there), and the USB-Modem port which accepts AT commands, including encrypted challenge-respose lock commands which need to be calculated by a server. Here's the log of the FRP unlock via server, after which I was able to activate ADB but not OEM Unlock or download mode:
Open Usb Port - PASS
Detected Testing - PASS
Read phone info....
Model Name : SM-G973F
Customer Code : TTT
S/W version : G973FXXU1ASE7
Unique Number : CE11182BF3538932xxxx
Serial Number : R28M30xxxx
Imei Number : 35463410028xxxx
Check Unlock Status - TRIGGERED
Start Clear Process
Please waiting ...
DBMS Get RandomKey... OK
DBMS Calculation RSAKey... OK
Finished - Successfully
Check Unlock Status - UNLOCK
So, still can't turn on OEM Unlock (grayed out), and can't enter download mode to flash an eng-boot/combination in order to erase the security partitions (persdata, persist, persistent, aboot-sec, etc)
Samsung may have some special resistor values or a special jig which could kick the phone into download mode, but I haven't found anything working along those lines.
The Following User Says Thank You to BillA For This Useful Post:
Old 06-28-2019, 05:29   #26 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 149
LITTLE MASTER
For MDM no download mode newer models means something tough in these days but work hard find pinouts you're welcome to J tagger's paradise
The Following User Says Thank You to gayansuranga For This Useful Post:
Old 06-29-2019, 02:35   #27 (permalink)
Member: 2754756
Thanks Meter: 20
New MDM security no dowload, no at comands, no 15 failes attemps of patternlock. Solution is JTAG only 100% tested on EMMC devices, and someday UFS.
Enviado desde mi SM-A505G mediante Tapatalk
The Following User Says Thank You to Krlozv94 For This Useful Post:
Old 06-30-2019, 00:56   #28 (permalink)
Little_Master's Avatar
Member: 1205146
Thanks Meter: 863
SO has ufs chip ,
Pinout available for ufs?
Old 06-30-2019, 18:42   #29 (permalink)
Member: 2251589
Thanks Meter: 16
which jtag are you using bro
Old 07-12-2019, 00:36   #30 (permalink)
Member: 567838
Thanks Meter: 57
For the procedure to remove MDM using EFT
1. What is the definition of boot image to make kernel
Please explain what file to use , stock rom ,combination file
2. Is EFT pro generated automatically or you have to create
Or download from somewhere
Please can you explain so I have better understanding thank you
Page generated in 0.19779 seconds with 7 queries
