08-07-2022, 06:30 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1029079 Status: Offline Thanks Meter: 61 | Sending File (kernel.img4).....OK But Failed Fix Drivers.........Is Fixed (No Need) Checking iDevices (PWNDFU).....OK Reading iDevice info.....OK Device NAME: iPhone X (GSM) Product NAME: iPhone10,6 Device ECID: 0x1124c6200a402e Device CPID: 8015 Device SRTG: IBOOT-3332.0.0.1.23 Device MODE: DFU Device CPU: A11 Exploiting Device [1].... Sending File (shsh.shsh).....OK Sending File (ibss.img4).....OK Sending File (ibec.img4).....OK Sending File (devicetree.img4).....OK Sending File (ramdisk.img4).....OK Exploiting Device [2].... Sending File (adc.img4).....OK Sending File (rdtrust.img4).....OK Sending File (kernel.img4).....OK Failed! Check Drivers and Re-enter in PWNDFU and Try Again Operation {Boot Passcode IOS 15.x} ID: 44A9D6E43BD35BA2 Kernel .img4 sent 100% then changes to 99% and failed Please help …. |
08-07-2022, 11:41 | #2 (permalink) | |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,230 | Quote:
The Following User Says Thank You to easy-team For This Useful Post: |
08-08-2022, 10:29 | #3 (permalink) |
Member: 1029079 Status: Offline Thanks Meter: 61 | please check the video it happens after sending file (kernel.img4) please check the video please tell me where i am doing wrong thanks in advance https://youtube.com/shorts/LBXMzDmKfgg?feature=share |
08-09-2022, 09:26 | #4 (permalink) | |
08-10-2022, 06:44 | #5 (permalink) |
Member: 1029079 Status: Offline Thanks Meter: 61 | I did it but not successful I TRIED BUT STILL THE SAME I HAVE SENT A FULL VIDEO PLEASE CHECK WHERE I AM WRONG https://www.youtube.com/watch?v=PTRy-ZPi_UU THANKS IN ADVANCE |
08-11-2022, 03:18 | #8 (permalink) |
Member: 1029079 Status: Offline Thanks Meter: 61 | installing udbdk didnt work installing usbdk did not help but i did a iphone 7 and all went fine and then i tried a 7+ and 6s+ THE SAME ERROR IS BACK I EVEN TRIEN REINSTALLING ITUNES BUT NO LUCK PLEASE TEAM GIVE A GOOD SOLUTION I CAN EVEN COME ON TEAM VIEWER IF NEEDED |
02-03-2023, 07:57 | #14 (permalink) |
Junior Member Join Date: Dec 2006 Location: argentina
Member: 409553 Status: Offline Thanks Meter: 0 | same problem! when sending file (kernel . img4) is finishing, driver "Apple Mobile Device USB driver" is disconnect, and no connect any driver after. If i press power, power and vol -, not working. No auto connect other driver, and after, phone turn on!! |
02-04-2023, 09:30 | #15 (permalink) | |
