03-09-2018, 20:22 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | SM-G935A/T/V/P/R4 SBL Upload Mode Error recovery W/ Mighty EFT dongle DONE ..This method does NOT use EDL cable. This method requires open the device.. ..No files needed, just EFT dongle.. Lets begin. PLEASE READ FULLY 1.. open device and remove main board 2.. follow detail pics to make TP ... make TP by solder wire to the point and GROUND 3.. Once made TP connections are solid, insert USB 4.. notice Windows device driver Qualcomm 9008 port notification ...(important) 5.. now we see if scan port on EFT the 9008 device (COMxx) 6.. now if YES from step Above, then DEsolder GROUND wire ... OR if NO, check TP again and start from step 2 ... 7.. device is now ready to recover from SBL Upload Mode, go to ... Unbrick Boot tab and select model and scan port. press Repair ... ... repair only takes a few seconds and device should be ready to ... flash repair firmware. Use button combo to enter download ... mode and flash 4_Files. tips: It is hard to make TP and have the board inside the phone frame. So the method that worked for me was just connect charging port flex cable to the board only. After you have made TP connection, scan the port and see 9008 COMxx in EFT software. That is all for enter 9008 mode so wire is not needed any longer. You can DEsolder it from the board but i just DEsoldered the GROUND side and continued to do the repair with EFT. Once the phone has been repaired you can pull battery and DEsolder the entire wire and reassemble the phone together. Thats it, just flash it now. Thanks EFT Dongle! NOTE: Detail pics are not here but for download. Follow the link to download TP pics (credit wadda7o) https://mega.nz/#!RCRUwCiT!gqEE2qRDF...6xwFJijg-IEC7c SHARE AND REPAIR ..BR.. .:112:. |
The Following 20 Users Say Thank You to Stunman112 For This Useful Post: |
03-10-2018, 06:10 | #4 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | |
The Following 2 Users Say Thank You to wadda7o For This Useful Post: |
03-27-2018, 03:45 | #6 (permalink) |
Freak Poster Join Date: May 2010 Location: angeles city,pampanga Age: 45
Member: 1304373 Status: Offline Thanks Meter: 31 | how bout g930p UNBRICK BOOT?how can i do it with eft dongle?i saw it on its support but dont know how to do it?is it possible that you can upload a video tutorial on how to unbrick boot on eft dongle?newbee in eft dongle.trhanks in advanced.hoping you could reconsider it.i have a deadboot g930p.i bought it to unbrick g930p. |
03-27-2018, 21:44 | #7 (permalink) | |
Member: 2567774 Status: Offline Thanks Meter: 255 | Quote:
Sent from my SM-G928T using Tapatalk | |
03-28-2018, 05:26 | #8 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | Quote:
03-28-2018, 23:39 | #13 (permalink) | |
04-19-2018, 19:19 | #14 (permalink) | |
Crazy Poster Join Date: Oct 2017
Member: 2770461 Status: Offline Thanks Meter: 22 | Quote:
From what I can tell, the loaders that have been made public for the G930 do not work on the P variant. The phone rejects the loader. | |
