Old 03-25-2020, 20:23   #1 (permalink)
Thanks Meter: 13,822
STK-L21M 10.0.0(C185) Downgrade Done by EFT Pro
Operation {Downgrade to reset FRP}
After Downgrade with this Firmware , use Safemode to reset FRP
STK-L21M 10.0.0(C185) Downgrade For FRP Bypass By EFT Pro (AOD)
Searching for upgrade port.....Detected {COM141}
Target model [STK-L21M 10.0.0(C185)]
Reading data from server.....OK
Bypassing downgrade protection.....OK
Rebooting device.....OK
Waiting device to reboot.....OK
- Reboot your device to upgrade mode:
1 - Reboot to recovery by Volume up button
2 - Press on (Update mode)
3 - Press on (USB update mode)
Waiting for upgrade mode device.....OK
Connecting to device.....OK
Start processing file [A.APP] 3,80 GB:
Flashing [sha256rsa.img].....OK
Flashing [crc.img].....OK
Flashing [base_verlist.img].....OK
Flashing [base_ver.img].....OK
Flashing [package_type.img].....OK
Flashing [hisiufs_gpt.img].....OK
Flashing [xloader.img].....OK
Flashing [fastboot.img].....OK
Flashing [hhee.img].....OK
Flashing [dts.img].....OK
Flashing [trustfirmware.img].....OK
Flashing [fw_lpm3.img].....OK
Flashing [dto.img].....OK
Flashing [kernel.img].....OK
Flashing [teeos.img].....OK
Flashing [isp_firmware.img].....OK
Flashing [vector.img].....OK
Flashing [sensorhub.img].....OK
Flashing [fw_hifi.img].....OK
Flashing [vbmeta.img].....OK
Flashing [modemnvm_update.img].....OK
Flashing [modemnvm_cust.img].....OK
Flashing [recovery_ramdisk.img].....OK
Flashing [recovery_vendor.img].....OK
Flashing [recovery_vbmeta.img].....OK
Flashing [erecovery_kernel.img].....OK
Flashing [erecovery_ramdisk.img].....OK
Flashing [erecovery_vendor.img].....OK
Flashing [erecovery_vbmeta.img].....OK
Flashing [eng_vendor.img].....OK
Flashing [eng_system.img].....OK
Flashing [cache.img].....OK
Flashing [system.img].....OK
Flashing [cust.img].....OK
Flashing [modem_fw.img].....OK
Flashing [hisee_img.img].....OK
Flashing [hisee_fs.img].....OK
Flashing [vendor.img].....OK
Flashing [odm.img].....OK
Flashing [product.img].....OK
Flashing [preas.img].....OK
Flashing [preavs.img].....OK
Flashing [patch.img].....OK
Flashing [userdata.img].....OK
Start processing file [O.APP] 3 MB:
Flashing [cust_verlist.img].....OK
Flashing [cust_ver.img].....OK
Flashing [ptable_cust.img].....OK
Flashing [version.img].....OK
Start processing file [D.APP] 340 MB:
Flashing [preload_verlist.img].....OK
Flashing [preload_ver.img].....OK
Flashing [ptable_preload.img].....OK
Flashing [preload.img].....OK
- Now go to recovery and do factory reset then use (Safe mode)
Operation {Downgrade to reset FRP} ID: 1E40EB96B3117DC1
Elapsed time 11:32 -- Version 1.9.6
Best regards
Easy Team
The Following User Says Thank You to easy-team For This Useful Post:
Old 03-25-2020, 20:50   #2 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 126
Good working team please add vivo,oppo and others
Qualcomm cpu thanks ?
Sent from my SM-G615F using Tapatalk
The Following User Says Thank You to kundicom For This Useful Post:
Old 03-25-2020, 20:56   #3 (permalink)
Qualcomm will be released after the end of Corona Crisis
The Following 4 Users Say Thank You to easy-team For This Useful Post:
Old 03-25-2020, 21:44   #4 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 601
Whats wrong with me ? Have i done wrong ?
Searching for upgrade port.....Detected {COM71}
Bypassing downgrade protection.....Failed: writing failed, Please contact support team
Operation {Downgrade to reset FRP} ID: 2B282D721BA36616
Elapsed time 00:39 -- Version 1.9.6
Inside firmware version.
Checking fastboot device.....OK
Reading info.....OK
Device Model: STK-L21
Device Firmware: :STK-L01M 10.0.0.185(C316E4R4P1)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: 4202EFB74FEFCF81
Elapsed time 00:02 -- Version 1.9.6
Old 03-25-2020, 22:02   #5 (permalink)
Reading info.....OK
Device Lock: locked
Your Device is STK-L01M , reqest your device to be supported
Old 03-25-2020, 22:12   #6 (permalink)
Member: 1444462
Thanks Meter: 601
Thanks bro, I have already sent the messages to your development team in the way you suggested.
The Following User Says Thank You to ..::GMSR::.. For This Useful Post:
Old 03-25-2020, 22:14   #7 (permalink)
it is not an immediate support but we will try as fast as we can !
The Following 2 Users Say Thank You to easy-team For This Useful Post:
Old 03-25-2020, 22:26   #8 (permalink)
Member: 1444462
Thanks Meter: 601
if you don't mind, reason it's your thread! if you have any query or asking just you can also ask in this thread
Old 03-26-2020, 04:02   #9 (permalink)
Member: 2683134
Thanks Meter: 33
Here is procedure
Old 04-02-2020, 17:21   #10 (permalink)
you choose a model and you select wrong flash and your model is not supported ... +961 81717291 contact whats app
Page generated in 0.18522 seconds with 7 queries
