Old 09-08-2019, 08:18   #1036 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 58
sm-j320f/ds frp unlock Successfully
model selet sm-J320W8 AND OK
The Following User Says Thank You to bijoychowdry For This Useful Post:
Old 09-09-2019, 11:11   #1037 (permalink)
Member: 2233266
Thanks Meter: 158
j200h ime repire done
EASY-TEAM
Waiting For Android Device.......OK
Reading Device Info.......OK
Product: samsung
Device Chipset: Spread
Device Model: SM-J200H
Device Serial: R21H50Z0AAW
Android Version: 5.1.1
Android SDK: 22
Architecture: armeabi-v7a
Free space in system disk: 59.2M
Phone Mode: Normal Mode
Checking Root Permission.......OK
Writing First IMEI.......OK
Writing Second IMEI.......OK
Patching Certification Security.......OK
Done By EFT Dongle
The Following User Says Thank You to Yahia_Sb For This Useful Post:
Old 09-09-2019, 13:34   #1038 (permalink)
Gsm::Boiragi::'s Avatar
Member: 1816848
Thanks Meter: 70
Techno B1p frp less then 2 sec 1 click
Wating Device..........OK
CPU: MT6580
Chip Version: 0x0000ca00
Chip Ext Clock: EXT_26M
Writing Mode..........OK
Internal RAM:
Internal SRAM Size: 128.00 KB
External RAM: Type DRAM
External Ram Size: 1.00 GB
EMMC:
EMMC PART BOOT1 Size: 4.00 MB
EMMC PART BOOT2 Size: 4.00 MB
EMMC PART RPMB Size: 512.00 KB
EMMC PART USER Size: 7.28 GB
Battery:
Battery Voltage: 3951
Injection..........OK
Detecting Parts info............OK
[ID: 1] [preloader] BaseAddr(0x00000000) Size(0x00400000)
[ID: 8] [pgpt] BaseAddr(0x00000000) Size(0x00080000)
[ID: 8] [proinfo] BaseAddr(0x00080000) Size(0x00300000)
[ID: 8] [nvram] BaseAddr(0x00380000) Size(0x00500000)
[ID: 8] [protect1] BaseAddr(0x00880000) Size(0x00a00000)
[ID: 8] [protect2] BaseAddr(0x01280000) Size(0x00a00000)
[ID: 8] [persist] BaseAddr(0x01c80000) Size(0x03000000)
[ID: 8] [seccfg] BaseAddr(0x04c80000) Size(0x00040000)
[ID: 8] [lk] BaseAddr(0x04cc0000) Size(0x00060000)
[ID: 8] [lk2] BaseAddr(0x04d20000) Size(0x00060000)
[ID: 8] [boot] BaseAddr(0x04d80000) Size(0x01000000)
[ID: 8] [recovery] BaseAddr(0x05d80000) Size(0x01000000)
[ID: 8] [para] BaseAddr(0x06d80000) Size(0x00080000)
[ID: 8] [logo] BaseAddr(0x06e00000) Size(0x00800000)
[ID: 8] [odmdtbo] BaseAddr(0x07600000) Size(0x01000000)
[ID: 8] [expdb] BaseAddr(0x08600000) Size(0x00a00000)
[ID: 8] [vendor] BaseAddr(0x09000000) Size(0x0fa00000)
[ID: 8] [frp] BaseAddr(0x18a00000) Size(0x00100000)
[ID: 8] [tkv] BaseAddr(0x18b00000) Size(0x00100000)
[ID: 8] [tee1] BaseAddr(0x18c00000) Size(0x00500000)
[ID: 8] [tee2] BaseAddr(0x19100000) Size(0x00500000)
[ID: 8] [nvdata] BaseAddr(0x19600000) Size(0x02000000)
[ID: 8] [metadata] BaseAddr(0x1b600000) Size(0x02200000)
[ID: 8] [oemkeystore] BaseAddr(0x1d800000) Size(0x00200000)
[ID: 8] [secro] BaseAddr(0x1da00000) Size(0x00600000)
[ID: 8] [keystore] BaseAddr(0x1e000000) Size(0x00800000)
[ID: 8] [system] BaseAddr(0x1e800000) Size(0x5a000000)
[ID: 8] [cache] BaseAddr(0x78800000) Size(0x09800000)
[ID: 8] [userdata] BaseAddr(0x82000000) Size(0x14ef80000)
[ID: 8] [flashinfo] BaseAddr(0x1d0f80000) Size(0x01000000)
[ID: 8] [sgpt] BaseAddr(0x1d1f80000) Size(0x00080000)
Detecting Device info.......OK
Product: TECNO MOBILE LIMITED
Device Model: TECNO B1p
Sw Internal:
Build Date: Sat Mar 23 11:15:55 CST 2019
Chip Ver:
Android Version: 8.1.0
FRP RESET... [FRP] .....OK
All Done By EFT Dongle
Old 09-10-2019, 13:38   #1039 (permalink)
Member: 1981108
Thanks Meter: 8
EFT Dongle
Connecting Fastboot .......
Connecting Fastboot .......Ok
Model Phone: DRA-LX2
SW: DRA-LX2 1.0.0.155(C185)
Connecting Server .....RECEIVED
Connecting Server .....READY
Erase Done , The Device Will Reboot And Factory Reset
Reboot ...............OK
By EFT Dongle OK
The Following User Says Thank You to lakhssas For This Useful Post:
Old 09-11-2019, 07:57   #1040 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 30
eft pro 1.4 aum-l29 FRP remove done fstboot server metod
log
Checking fastboot device.....OK
Reading info.....OK
Device Model: AUM-L29
Device Serial: QDG9X18809W03036
Device IMEI: 869167049472068
Device Firmware: AUM-L29 8.0.0.151(C10)
Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT
Waiting for server.....OK
Reading data.....OK
Posting data to server.....OK
Waiting for server response.....OK
Unlocking device.....OK
Resetting FRP.....OK
Operation ID: 82896FE1625382AF6757AF3594001091
Elapsed time 00:39 -- Version 1.4
Old 09-11-2019, 16:34   #1041 (permalink)
AL-KARAM MOBILE's Avatar
Member: 1329373
Thanks Meter: 78
J530f U4 FRP
J530f FRP DONE WITH EFT PRO
https://ibb.co/gmmR9j7
Old 09-12-2019, 16:27   #1042 (permalink)
technomak's Avatar
Member: 2035802
Sonork: 100.1675827
Thanks Meter: 348
A7000 play store added
EASY-TEAM
Product: samsung
Device Chipset: Qualcomm
Device Model: SM-A7000
Device Serial: R28G43FZXMJ
Android Version: 5.0.2
Android SDK: 21
Free space in system disk: 180.9M
install gapps ............OK
Old 09-13-2019, 09:03   #1043 (permalink)
Member: 2532428
Sonork: https://t.me/BotirJon
Thanks Meter: 13
Huawei dra-lx5
Unlock FRP Done !
Reading info.....OK
Device Model: DRA-LX5
Device Serial: VUY9K18A15905177
Device IMEI2: 8665670******
Device Firmware: DRA-LX5 1.0.0.127(C10)
Device Lock: Check root info is safe | Lock state is lock | Check System: PASS | Root State: UNROOT
Reading data.....OK
Operation ID: 014876BE77A928A6D29DD37BB3F20123
Elapsed time 00:14 -- Version 1.4
Old 09-13-2019, 14:53   #1044 (permalink)
Crazy Poster
Member: 2767980
Thanks Meter: 24
Smile SM-A510F U8 Reset FRP one click using EFT
SM-A510F U8 7.0 Reset FRP one click using EFT
Old 09-13-2019, 15:08   #1045 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 761
can i add ethopian language amharic to any samsung mobile thanks
Old 09-13-2019, 16:19   #1046 (permalink)
Member: 2233266
Thanks Meter: 158
samsung g532f one click frp done
Opening Port COM5...........OK
Verifying Download Mod
OK
Initialization.......OK
Reading Phone Partitation Table........OK
Partition Size : 8192
Unpak pit .......OK
FLASHING FIRMWARE TO PHONE.....
Sending data: ..........OK
Sending data2: ........OK
FLASHING DONE!
Rebooting PDA TO NORMAL MODE........OK
Please Enter your device into recovery mode
Waiting Adb in Recovery Mode.....DONE
Detecting Device Info.....DONE
Device Model: SM-G532F
Device CPU: armeabi-v7a
Android SDK: 23
Android Version: 6.0.1
Resetting Samsung Account / Frp .....
Found protection1
Protection1 has been deleted
Found protection2
Protection2 has been deleted..OK
Old 09-13-2019, 19:12   #1047 (permalink)
louka's Avatar
Member: 198016
Sonork: 100.1602918
Thanks Meter: 406
Huawei Mate 10 lite - RNE-L21 - FRP DONE
Waiting for USB COM 1 port.....Detected {COM309}
Connecting to device.....OK
Writing data 1.....OK
Writing data 3.....OK
Rebooting device to fastboot.....OK
Waiting for fastboot device.....OK
Reading info.....OK
Device Model: RNE-L21
Device Serial: FFY5T18424021346
Device IMEI: 8696760xxxxxxxx
Device IMEI2: 8696760xxxxxxxx
Device Firmware: :RNE-L21 8.0.0.339(C185)
Device FB Lock: UNLOCKED
Device USER Lock: LOCKED
Device Lock: unlocked
Operation ID: A5A0B70EE721677B331A51E7C54E09BE
Elapsed time 00:30 -- Version 1.4
Old 09-14-2019, 08:18   #1048 (permalink)
rsa7262's Avatar
Member: 2470191
Sonork: 100.1652036
Thanks Meter: 228
Y3 2018 (CAG-L22)Successfully Reset Done by Great EFT Tool
CPU: MT6737M
Internal RAM:
EMMC:
Battery:
Battery Voltage: 4051
[ID: 8] [para] BaseAddr(0x01c80000) Size(0x00080000)
[ID: 8] [lk] BaseAddr(0x01d00000) Size(0x00100000)
[ID: 8] [boot] BaseAddr(0x01e00000) Size(0x01000000)
[ID: 8] [bfr] BaseAddr(0x02e00000) Size(0x000c0000)
[ID: 8] [misc] BaseAddr(0x02ec0000) Size(0x00010000)
[ID: 8] [bootfail_info] BaseAddr(0x02ed0000) Size(0x00200000)
[ID: 8] [rrecord] BaseAddr(0x030d0000) Size(0x00800000)
[ID: 8] [nff] BaseAddr(0x038d0000) Size(0x00200000)
[ID: 8] [odmdtbo] BaseAddr(0x03ad0000) Size(0x00080000)
[ID: 8] [reserved0] BaseAddr(0x03b50000) Size(0x00230000)
[ID: 8] [logo] BaseAddr(0x03d80000) Size(0x00200000)
[ID: 8] [expdb] BaseAddr(0x03f80000) Size(0x00a00000)
[ID: 8] [seccfg] BaseAddr(0x04980000) Size(0x00080000)
[ID: 8] [oemkeystore] BaseAddr(0x04a00000) Size(0x00200000)
[ID: 8] [secro] BaseAddr(0x04c00000) Size(0x00200000)
[ID: 8] [keystore] BaseAddr(0x04e00000) Size(0x00800000)
[ID: 8] [tee1] BaseAddr(0x05600000) Size(0x00100000)
[ID: 8] [tee2] BaseAddr(0x05700000) Size(0x00100000)
[ID: 8] [bak] BaseAddr(0x05800000) Size(0x00800000)
[ID: 8] [bakraw] BaseAddr(0x06000000) Size(0x00100000)
[ID: 8] [dfx] BaseAddr(0x06100000) Size(0x00100000)
[ID: 8] [recovery] BaseAddr(0x06200000) Size(0x02000000)
[ID: 8] [erecovery] BaseAddr(0x08200000) Size(0x02000000)
[ID: 8] [log] BaseAddr(0x0a200000) Size(0x02200000)
[ID: 8] [frp] BaseAddr(0x0c400000) Size(0x00100000)
[ID: 8] [oeminfo] BaseAddr(0x0c500000) Size(0x00800000)
[ID: 8] [nvdata] BaseAddr(0x0cd00000) Size(0x02000000)
[ID: 8] [metadata] BaseAddr(0x0ed00000) Size(0x02300000)
[ID: 8] [odm] BaseAddr(0x11000000) Size(0x01800000)
[ID: 8] [vendor] BaseAddr(0x12800000) Size(0x0c000000)
[ID: 8] [system] BaseAddr(0x1e800000) Size(0x5e000000)
[ID: 8] [cache] BaseAddr(0x7c800000) Size(0x07800000)
[ID: 8] [userdata] BaseAddr(0x84000000) Size(0x14cf80000)
Product: HUAWEI
Device Model: CAG-L22
ID:
Sw Internal:
Build Date: Fri Oct 12 17:53:31 CST 2018
Chip Ver:
Formating... [USERDATA] .....OK
Old 09-14-2019, 13:23   #1049 (permalink)
Member: 2401943
Thanks Meter: 135
Analyzing file.....OK
Searching for Samsung ODIN protocol.....Detected {COM76}
Device Model.....SM-G930A
Reading PIT.....OK
Flashing [data 1].....OK
Rebooting device.....OK
Waiting for device.....OK
Reading device info.....OK
Baseband Version: G930AUCUACSF1
Serial Number: R38H208P2HT
Device Arch: msm8996
Device bootloader: G930AUCUACSF1
Device selinux: permissive
Device warranty bit: 0
Device Firmware: G930AUCUACSF1
Android version: 8.0.0
Device SDK: 26
Device data encryption: encrypted
Firmware Country: USA
Device Hardware: qcom
Device CPU: arm64-v8a
Device Factory: samsung
Device Model: SAMSUNG-SM-G930A
Device IMEI:
Root status.....Rooted { Adb direct }
Operation ID: CE5A82C5D886C8826ABCEDD49C204D66
Elapsed time 02:10 -- Version 1.4
Old 09-16-2019, 07:22   #1050 (permalink)
Member: 2765424
Thanks Meter: 579
samsung a750f u1 9.0 root done
EASY-TEAM
Product: samsung
Device Chipset: samsungexynos7885
Device Model: SM-A750F
Device Serial: RF8M10L9GBV
Android Version: 9
Android SDK: 28
Architecture: arm64-v8a
Free space in system disk: 311M
Checking Root Permission.......Fail
root done
EASY-TEAM
Product: samsung
Android Version: 9
Android SDK: 28
Page generated in 0.23740 seconds with 8 queries
