02-14-2019, 17:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | volume size too big (Solved) i flashed with combination COMBINATION_FA60_G935PUCU5ARA2_CL11071963_QB163945 37_REV02_user_mid_noship_MULTI_CERT then phone full working in factory binary mode (but phone model shows G935A ) but when flashing back stock rom of g935P it stops at system and screen shows volume size is too big 1228800<1300400 ODIN- Invalid id ext4 image now phone cant to full power on only have samsung logo changed 3 files same condition give any solution Sabah Mangattupulam Malappuram India |
The Following User Says Thank You to Abussabah For This Useful Post: |
02-14-2019, 17:58 | #2 (permalink) | |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Quote:
just check recovery because at this time many covert firmware availble like G930P to G930F | |
The Following 2 Users Say Thank You to sajidi1984 For This Useful Post: |
02-14-2019, 18:02 | #3 (permalink) | |
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Quote:
after i flashing combination it become g935A after flashing stock which is stuck at system it is now shows g935P | |
02-14-2019, 18:07 | #4 (permalink) | |
your problem will be solve | |
The Following User Says Thank You to sajidi1984 For This Useful Post: |
02-14-2019, 23:54 | #5 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | As long as your device is showing G935A in bootloader now then try to flash stock G935A rom, flash system at least from G935A same binary ! |
The Following 2 Users Say Thank You to easy-team For This Useful Post: |
02-15-2019, 15:06 | #6 (permalink) | |
at first time it was G935P all combination of G935P came as G935A, after flashing combination G935P normally see as G935A. now phone can fully on by flashing G935a or G935U but in both firmware no network shows invalid sim mipi devce failed also. first time network was ok | |
02-15-2019, 16:05 | #7 (permalink) |
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Invalid means your device needs to be unlocked , Just root and unlock |
The Following 4 Users Say Thank You to easy-team For This Useful Post: |
02-17-2019, 08:11 | #10 (permalink) |
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | finally solved the problem, will say detail after Sabah Mangattupulam Malappuram India |
02-18-2019, 08:35 | #11 (permalink) | |
first flash G935U boot u8 after phone full working but invalid sim, when check *#0011# mipi and cert failed then flashing complete using G935P boot U8 (before flashing G935U it was failed on system, now it is complete) phone full working but invalid sim , when check *#0011# mipi and cert pass but unlocking failed. for unlock need write this file download falsh this file and unlock using any box. after this full flash using G935P U8 (i think in this step it need only CP file writing) after this phone full working , network ok, model same as first ie G935P Sabah Mangattupulam Malappuram India | |
The Following 3 Users Say Thank You to Abussabah For This Useful Post: |
