10-15-2019, 02:33 | #1 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2652218 Status: Offline Thanks Meter: 0 | VTR-L09 DEAD after flash Boardsoftware by eft board software was charged by test point, after loading, the pc detects in fastboot but does not display, or turn on only in fastboot, is there any solution? The firmware you upload is: HLVTRAL00M00A063_Download |
10-15-2019, 02:47 | #2 (permalink) |
Member: 2652218 Status: Offline Thanks Meter: 0 | Extracting files.....Done Waiting for device to connect.....Found {COM36} Opening Port.....OK Writing xloader.....OK Writing usb xloader.....OK Writing fastboot.....OK Rebooting to fastboot.....OK Connecting Fastboot ....... Connecting Fastboot .......Ok Model Phone: :FAILED SW: :FAILED Android Version: FAILED IMEI: :FAILED Lock state: FBLockState:UNLOCKED USERLockState:LOCKED Boot info: unlocked battery: 3518mv flash : huawei_crc_check..........OK flash : xloader..........OK flash : huawei_crc_check..........OK flash : ptable..........OK flash : huawei_crc_check..........OK flash : fastboot..........OK flash : huawei_crc_check..........OK flash : vector..........OK flash : huawei_crc_check..........OK flash : dts..........OK flash : huawei_crc_check..........OK flash : fw_lpm3..........OK flash : huawei_crc_check..........OK flash : sensorhub..........OK flash : huawei_crc_check..........OK flash : fw_hifi..........OK flash : huawei_crc_check..........OK flash : teeos..........OK flash : huawei_crc_check..........OK flash : recovery..........OK flash : huawei_crc_check..........OK flash : cache..........OK flash : huawei_crc_check..........OK flash : boot..........OK flash : huawei_crc_check..........OK flash : nvme..........OK flash : huawei_crc_check..........OK flash : trustfirmware..........OK flash : huawei_crc_check..........OK flash : modem_fw..........OK flash : huawei_crc_check..........OK flash : modemnvm_update..........OK flash : huawei_crc_check..........OK flash : modem_om..........OK flash : huawei_crc_check..........OK flash : modemnvm_img..........OK flash : huawei_crc_check..........OK flash : isp_firmware..........OK flash : huawei_crc_check..........OK flash : userdata..........OK flash : huawei_crc_check..........OK flash : system..........OK flash : huawei_crc_check..........OK flash : vendor..........OK flash : huawei_crc_check..........OK flash : product..........OK flash : huawei_crc_check..........OK flash : version..........OK flash : huawei_crc_check..........OK flash : splash2..........OK flash : huawei_crc_check..........OK flash : frp..........OK flash : huawei_crc_check..........OK flash : oeminfo..........OK flash : huawei_crc_check..........OK flash : secure_storage..........OK flash : huawei_crc_check..........OK flash : modem_secure..........OK flash : huawei_crc_check..........OK flash : hisee_img..........OK flash : huawei_crc_check..........OK flash : hisee_fs..........OK flash : huawei_crc_check..........OK flash : reserved4..........OK flash : huawei_crc_check..........OK flash : efuse..........OK flash : huawei_crc_check..........OK flash : ufs_fw..........OK Reboot ...............OK after flash: EFT Dongle Connecting Fastboot ....... Connecting Fastboot .......Ok Model Phone: :FAILED SW: :FAILED Android Version: FAILED IMEI: :FAILED Lock state: FBLockState:LOCKED USERLockState:LOCKED Boot info: locked battery: 0 |
