01-30-2018, 14:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: PUNJAB Age: 41
Member: 914898 Status: Offline Sonork: 100.1597109 Thanks Meter: 117 | a2020a40 imei repair not done [ANSWERED] alredy do with wipe sec handset factory reset backup sec with working handset not done Checking Current Version Current Version OK Checking User Login User Login OK. Searching Device Devie Found !! Selected Port : COM4 Reading Device Info. Compile Date : Release Date : Model ID : Build ID : MEID : 000D0000001000 IMEI : 1000000D0000000 ESN : 00001000 Device : Qualcomm New IMEI : **********00690 New IMEI 2 : **********04108 Writting IMEI ... Please Wait ... Writting IMEI 1 Sucessful!! Writting IMEI 2 Sucessful!! Rebooting Device If it does not Auto Reboot Please Reboot it Manually, do not Remove Battery. Elapsed Time : 0 minutes - 3 seconds |
01-30-2018, 14:37 | #2 (permalink) |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Hello, Please Read Hints inside the tool, You are not select Diag port Lenovo IMEI Repair ========================================= 1 - Power Off Device 2 - Press and hold vol- and insert usb cable 3 - Wait device to be in Test mode 4 - Select diag Port and Repair IMEI 5 - if Device not goes in test mode then you need enable diag manually 6 - If in any case imei not repair you may need wipe security first. ========================================= BR |
The Following User Says Thank You to namyelus For This Useful Post: |
02-02-2018, 14:58 | #3 (permalink) | |
Member: 914898 Status: Offline Sonork: 100.1597109 Thanks Meter: 117 | Quote:
Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM4 ] Analyzing Please wait ... MODEL : Lenovo Vibe C A2020A40 MEM_TYPE : EMMC BLOCK_ID_S : 089D9FFE BLOCK_ID_L : 00000000 BLOCK_ID_H : CC3153A80293939B90D02D3BF8B23E02 BLOCK_ID_H : 92E452FEF662C74998421ADAD42A380F Starting Lenovo Wipe Security Method Reading Data .. Please wait Sending loader Please wait ... Loader successfully Sent ... Model : Lenovo A2020a40 Android Version : 5.1.1 Name : angus3A4 Display ID : A2020a40_S189_161109_ROW Device : angus3A4 Manufacturer : LENOVO Product : angus3A4 Scanning Security Area .. Please wait.. Wiping Security Please wait Wipe Security done.. All Process Successfuly Done. Rebooting Device. | |
02-02-2018, 15:03 | #4 (permalink) | |
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Quote:
What not done ? Now Enable diag Manuelly or Put device test mode and Write imei on diag port -> Next Time Without confirmation and details your topic will deleted! BR | |
