09-05-2017, 11:52 | #1 (permalink) |
Insane Poster Join Date: Sep 2017 Location: ITALY
Member: 2754239 Status: Offline Thanks Meter: 16 | A510F write cert failed uat 3.0.2 i try write cert file on a510f with uat 3.0.2 this is a error log ----------------------------------------------------- Please Follow These steps : 1 - Put Uart Cable and Screen Must be active 2 - Dial *#0*# To enter Test mode Device. Searching Device...... Devie Found !! Writing Cert... Please Wait... Reading Data From Device... Input AKSEED : 565-33-5 Output AKSEED : 192-93-98 Sending MSL to Device Sending MSL to Device Failed... Please Try Wipe EFS or Security Then Try again! ------------------------------------------------------ i drowngrade the phone to 6.0.1 from 7.0 security patch is 1 march 2017 the phone is rooted this is full info ------------------------------------------------------ -- Starting Adb Server : Done -- Searching Device -- Found -- MODAL : SM-A510F -- MANUFUCTURER : samsung -- ANDROID VERSION : 6.0.1 -- CPU : armeabi-v7a -- CHIPSET : exynos7580 -- MMC STORAGE : 14,68 GB -- HARDWARE : samsungexynos7580 -- BOARD : universal7580 -- BOOTLODER : A510FXXU4BQC1 -- USB CONFIG : mtp,adb -- USER : dpi -- BASEBAND : A510FXXU4BQC3 -- DISPLAY ID : MMB29K. A510FXXU4BQC1 -- BUILD ID : MMB29K -- PDA : A510FXXU4BQC1 -- SIM STAT. : ABSENT -- KNOX VER. : 2.5.0 -- SERIAL NO. : R58HB4Z2SLE -- SOFT VERSION : A510FXXU4BQC3 -- TIME ZONE : Europe/Rome -- BUILD DATE : Fri Mar 3 16:39:47 KST 2017 -- BUILD TAGS : release-keys -- COUNTRY CODE : Germany -- NETWORK TYPE : Unknown -- SIM OPERATOR : -- LCD DENSITY : 480 -- IMEI 1 : -- ROOT STATUS -- Superuser. Apk : Installed -- BusyBox : Not Installed -- Su Binararies : 2.79 -- Root Status : ROOTED -- Elapsed Time : 0 minutes - 11 seconds ---------------------------------------------------------------- wipe efs ok wipe security failed error ( try to write security) the write button is disabled on uat 3.0.2 help me please can i downgrage the security patch? thanks and sorry for my english |
09-05-2017, 17:03 | #6 (permalink) |
Member: 2754239 Status: Offline Thanks Meter: 16 | i flash this firmware is 6.0.1 no 5.1.1 i flash twrp recovery and root device open uat tool and try wipe security failed try write cert failed same problem ------------------------------------------------------------------- -- Searching Device -- Found -- MODAL : SM-A510F -- MANUFUCTURER : samsung -- ANDROID VERSION : 6.0.1 -- CPU : armeabi-v7a -- CHIPSET : exynos7580 -- HARDWARE : samsungexynos7580 -- SERIAL NO. : R58HB4Z2SLE -- SOFT VERSION : A510FXXU4BQC3 -- TIME ZONE : Europe/Rome -- BUILD DATE : Fri Mar 3 16:39:47 KST 2017 -- BUILD TAGS : release-keys -- COUNTRY CODE : Germany -- Checking Root Status !! -- Rooted -- Su Binararies : 2.79 -- Operation : WIPE SECURITY -- Wiping Security....Please Wait -- Rebooting Device.... -- Wiping security fail, Please write Security backup !! Please Follow These steps : 1 - Put Uart Cable and Screen Must be active 2 - Dial *#0*# To enter Test mode Device. Searching Device...... Devie Found !! Writing Cert... Please Wait... Reading Data From Device... Input AKSEED : 721-170-23 Output AKSEED : 499-94-122 Sending MSL to Device Sending MSL to Device Failed... Please Try Wipe EFS or Security Then Try again! ------------------------------------------------------------------------------ i try flash combination fili 5.1.1 root an try wipe security failed write cert failed ------------------------------------------------------------------ -- Searching Device -- Found -- MODAL : SM-A510F -- MANUFUCTURER : samsung -- ANDROID VERSION : 5.1.1 -- CPU : armeabi-v7a -- CHIPSET : exynos7580 -- HARDWARE : samsungexynos7580 -- SERIAL NO. : R58HB4Z2SLE -- SOFT VERSION : A510FXXU4AQC2 -- TIME ZONE : Europe/Rome -- BUILD DATE : Thu Mar 9 17:05:10 KST 2017 -- BUILD TAGS : release-keys -- Checking Root Status !! -- Rooted -- Su Binararies : 2.79 -- Operation : WIPE SECURITY -- Wiping Security....Please Wait -- Rebooting Device.... -- Wiping security fail, Please write Security backup !! ------------------------------------------------------------------- have any idea? |
