09-28-2017, 13:59 | #1 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2754474 Status: Offline Thanks Meter: 3 | Asus Z00ED MSM 8916 frp reset failed... need help... [Solved] Last edited by Mehmood Riaz 1; 10-08-2017 at 14:04. Reason: wrong cpu type... |
10-03-2017, 08:42 | #7 (permalink) | |||
Product Manager Join Date: Jul 2009 Location: GsmGenesis
Member: 1084080 Status: Offline Thanks Meter: 8,226 | Quote:
You Can Post Logs , So Provide us logs , After 10 Posts You will able to Post Screen Shot | |||
The Following User Says Thank You to MUKESH RAJ For This Useful Post: |
10-06-2017, 04:31 | #9 (permalink) |
Member: 2754474 Status: Offline Thanks Meter: 3 | -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Searching Device - -- Fastboot Device Found -- Reading Device Info. -- Version : 0.5 -- Product : MSM8916 -- Serial No : F9AZCY10M -- Operation : QUALCOMM FRP RESET -- Resetting Frp Please wait... -- Frp Reset Failed -- Operation Aborted -- Elapsed Time : 0 minutes - 1 seconds |
10-06-2017, 09:21 | #10 (permalink) | |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Quote:
Please Usnig ASUS Tab for ASUS FRP | |
10-07-2017, 04:38 | #12 (permalink) |
Member: 2754474 Status: Offline Thanks Meter: 3 | -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. Searching Device - Fastboot Device Found Reading Device Info. Version : 0.5 Product : MSM8916 Serial No : F9AZCY10M Sending Data : Done Executing Exploit : Done using Asus FRP Reset Tab.... it says done the phone resets... boot up and still the unit ask for a previously used email... what to do next... |
10-07-2017, 10:20 | #13 (permalink) | |
BR | |
10-07-2017, 12:47 | #14 (permalink) |
Member: 2754474 Status: Offline Thanks Meter: 3 | the device since was hard resetted by the customer... so it always goes to the first factory setup... this is what i did... i tried booting on the phone... tried to enable adb tru UAT... and nothing happens second from off state... i go to fastboot mode by pressing vol + and power... tried FRP reset failed so far... third from off state... i go to fastboot mode and enable adb thru UAT... restarts by itself and then bootup normally... which puts me into the factory setup again and asking again of previously used email... and then tried to FRP reset thru there... failed... fourth from off state... i go to fastboot mode... FRP reset thru Asus Tab... no failed status... it says done... and then restarts by itself... boot normally... goes back to factory setup and still ask for previously used email... ive done everything possible... maybe i have done something wrong in my procedure... if so can you help me if ever ive done something wrong... tnx in advance... |
10-08-2017, 13:57 | #15 (permalink) |
Member: 2754474 Status: Offline Thanks Meter: 3 | -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. Searching Device - Fastboot Device Found Reading Device Info. Version : 0.5 Product : MSM8916 Serial No : F9AZCY10M Sending Data : Done Executing Exploit : Done Switching Device to Adb Mode Please Check device screen Allow Adb Authorization if Prompted. Waiting for Device to Connect Again Device Found MODAL : ASUS_Z00ED MANUFUCTURER : asus ANDROID VERSION : 6.0.1 CPU : arm64-v8a HARDWARE : qcom BUILD DATE : Thu Feb 2 15:30:41 CST 2017 BUILD TAGS : release-keys Checking Root Status !! Not Rooted Resetting Frp Please wait... Frp Reset done Elapsed Time : 0 minutes - 7 seconds at last success in FRP reset... tnx a lot UAT team... |
The Following User Says Thank You to duckmaster For This Useful Post: |
