Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT
Old 07-08-2019, 16:10   #1 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 619
Thumbs up a funny bug help
im trying to repair imei on uni-tool but it saying device not found but port is appearing in logs
Connecting Com Port..
Device Not Found !
Please Check Cable or Port
Port : COM34 : Qualcomm HS-USB Android DIAG 9020 (COM34)
Baud Rate : 115200
Method : EFS Method
New IMEI 1 : 352170061018284
New IMEI 2 : 352170061018284
Searching Device...
Device Not Found
this is totally unbelievable
Old 07-08-2019, 16:19   #2 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,796
Device Not Found !
Baud Rate : 115200
Method : EFS Method
Searching Device...
Device Not Found
This is not funy these 3 lines itself says
Device Not Found !
remaining information are custom ... your new inserted IMEI's and port selected.
Please post Screen Shot for better understand, usually this issue comes from drivers.
Which IMEI Method you tried ?
The Following 2 Users Say Thank You to Mehmood Riaz 1 For This Useful Post:
Old 07-15-2019, 17:48   #3 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 84
Also if you do an operation incorrectly most the time it is needed that you disconnect, restart phone (sometimes not needed), reconnect and put phone back into mode of method you were using on current previously failed operation and try again. This most of the time is something a lot of people overlook and wonder why an operation keeps failing. (make sure like Mehmood Riaz 1 said to check method, drivers and port selected also (double check with device manager always is good)
Old 07-15-2019, 17:56   #4 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 84
Oh yeah.. maybe try to get diag 901D.. not sure about the many qualcomm diag drivers but general there is i thought 2 default Qualcomm diag that show up on generic devices.. (with drivers installed) 901D and maybe your 9020? 901D is always what I have used.
Could be wrong, still have more leaning to do. Just a little help.
Also what paid subscription version are you using?
Page generated in 0.16160 seconds with 7 queries
