11-04-2018, 13:34 | #1 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2511098 Status: Offline Thanks Meter: 41 | G890A 7.0 U7 drk error not solved with UART and ADB+root -- Current Version OK -- Checking User Login -- User Login OK. -- Searching Device -- Device Found -- Reading Device Info. ... MR2B MR1B PWRON1S PMIC_STATUS2 = 0x10 RTC1SE PMIC_PWRONSRC = 0x08 MRST PMIC_OFFSRC = 0x00 PMIC_INT1 = 0x43 PWRONF PWRONR PWRON1S PMIC_INT2 = 0x10 RTC1S PMIC_INT3 = 0x80 RSVD PMIC_RTC_CTRL = 0x02 PMIC_RTC_SMPL = 0x03 RTC TIME: 2018-11-04 12:30:03(0x01)PM s5p_check_keypad: 0x0 s5p_check_reboot_mode: INFORM3 = 12345674 ... setting REBOOT_MODE to 4 clearing SALES_CODE ATLAS_PLL = 1200MHz APOLLO_PLL = 1200MHz MIF_PLL = 3104MHz MFC_PLL = 468MHz CCI_PLL = 532MHz BUS0_PLL = 1600MHz BUS1_PLL = 668MHz board_uart_rustproof ifc_sense: 0 -user build & not FAC -rustproof mode Enabled s5p_check_upload: MAGIC(0x0), RST_STAT(0x20000000) max77843_muic_get_adc_value: STATUS1:0x1c max77843_muic_get_adc_value: ADC:0x1c s5p_check_upload: debug level is LO! (mask: 0x80) max77843_ific_set_mrstb: TOPSYS: MAINCTRL1[0x02]: [0x87]+[0x07]->[0x07] s5p_check_upload: disable dump_gpr s5p_check_download: 0 mach_board_main: recovery set!(0x80000) max77843_muic_get_adc_value: STATUS1:0x1c max77843_muic_get_adc_value: ADC:0x1c max77843_get_charger_status: Invalid charger check_pm_status: normal reset, do not enter LPM mode. scr_draw_image: draw 'logo.jpg'... read 'logo.jpg'(125872) completed. LoadJPEG took 214 msec board_set_dev_pm: s2mpb02 enable for display 43, 0, 13, 0x430013 DETECTED LCD TYPE : S6E3HA2 mipi-dsi driver(CMD mode) has been probed. decon-int: ver0, max win7, command mode, hw trigger single dsi mode decon0 registered successfully Set debug level to low(4f4c) DMV: Successfully informed TZ of boot mode: Recovery load_kernel: loading boot image from 139264.. kernel size = 0x141f800, ramdisk size = 0x740000 dt_size:548864, dt_actual:548864 Verify_Binary_Signature 0x45720120 29253664@0x40204800, 256@0x45720020 Kernel Image pit_check_signature (RECOVERY) valid. [TIMA trusted boot]: SEANDROID ENFORCING No need to update kernel type. ace_hash_sha_digest: passed.(0) tboot ctx base: 45720248 SMC Num = 0x83000001 mobismc success!!! [ret = 0] SMC Num = 0x83000007 mobismc for tima info success!!! [ret = 0] Pass. DTBH size is smaller than a page. <dtbh_header Info> magic:0x48425444, version:0x00000002, num_entries:0x00000003 <device info> chip_id: 0x00001cfc platform_id: 0x000050a6 subtype_id: 0x217584da hw_rev: 0x00000005 dt_entry[02] chip_id: 0x00001cfc platform_id: 0x000050a6 subtype_id: 0x217584da hw_rev: 0x00000003 hw_rev_end: 0x000000ff offset: 0x00059800 dtb size: 0x0002c800 Selected entry hw_ver : 5 dt_entry of hw_rev 3 is loaded at 0x4a000000.(182272 Bytes) [EFUSE] RB count: device(0x5), binary(0x5) Kernel RB count: DEVICE:2, BINARY:2 [OTP] SW LOCK Success DDI value :0x00000000 Forced Enable KAP Warranty Bit Check passed with KAP param status = 1526595585 Yes KAP mode - ****ing TZ_KAP_BOOT_STATUS_FUSE KAP status = 5afe0001 afw flag is Unknown [afw flag : 00 00 00 00] secure info base: 4572000Model : Customer Code : Software Version : Unique Number : Reparing Dev Root Key....Please Wait! Dissable Sleep Mode.. OK Checking Cert Status..... IMEI CERT : Pass Checking DRK Status..... DRK Repair Started..... Stage 1 Done..... Stage 2 Done..... Stage 3 Done..... Stage 4 Done..... Stage 5 Done..... Stage 6 Done..... Stage 7 Done..... Stage 8 Done..... Stage 9 Done..... Stage 10 Done..... Stage 11 Done..... Device Rebooting.... DRK Repair Successfully!! Device Rebooting....if not please do it manually! |
The Following User Says Thank You to Djugurtha26 For This Useful Post: |
