Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool
Old 07-22-2017, 18:42   #1 (permalink)
namyelus's Avatar
Member: 2709688
Sonork: 100.1624755
Thanks Meter: 1,340
GUIDE - How to Repair IMEI of Qualcomm Devices [Look Here]
- Root the Device
- Enable USB Debug
1 - Backup Security (Against any possibility)
2 - Wipe Security
3 - Enable Diag
4 - Select Any Method for Write IMEI
The Following 12 Users Say Thank You to namyelus For This Useful Post:
Old 07-23-2017, 06:42   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,196
Is there any require of security backup if a device need to Repair IMEI ?
Yes its require when one want to change IMEI .
Br - srinibas
The Following 3 Users Say Thank You to srinibas For This Useful Post:
Old 08-08-2017, 22:27   #3 (permalink)
Member: 648045
Thanks Meter: 3
I've tried it and it just does not come out in huawei y625
Old 08-12-2017, 00:27   #4 (permalink)
karunkrsna's Avatar
Member: 1286646
Thanks Meter: 12
please how root zte z812
- Root the Device
- Enable USB Debug
2 - Wipe Security
3 - Enable Diag
how root zte z812
Old 08-13-2017, 13:50   #5 (permalink)
Member: 1168670
Sonork: 1614373
Thanks Meter: 18
hi
yes . you must root your device then enable diag mode and repair imei
but after that you need to write tested qcn to have signal
Old 11-10-2017, 18:53   #6 (permalink)
Member: 1486278
Thanks Meter: 2
repair imei xiaomi red mi 2
Old 11-11-2017, 13:39   #7 (permalink)
namyelus's Avatar
Member: 2709688
Sonork: 100.1624755
Thanks Meter: 1,340
its Already Supported, without unlock bl and root.
Old 01-20-2018, 12:42   #8 (permalink)
Member: 1917749
Thanks Meter: 30
i need help boss please help me
Old 01-28-2018, 05:19   #9 (permalink)
Member: 2771853
uni-android tool hv a UART interface?
Old 02-15-2018, 10:38   #10 (permalink)
Member: 2811572
Hi, Does it support the Huawei GR5 (KII-L21) ?
Old 03-24-2018, 01:05   #11 (permalink)
Member: 2635001
suport motorola xt1650?
Old 03-25-2018, 13:58   #12 (permalink)
Member: 2721278
-- Searching Device
-- Found
-- MODAL : moto x4
-- MANUFUCTURER : motorola
-- ANDROID VERSION : 8.0.0
-- CPU : arm64-v8a
-- HARDWARE : qcom
-- BUILD DATE : Wed Jan 31 05:20:12 CST 2018
-- BUILD TAGS : release-keys
-- Checking Root Status !!
-- Permission denied
-- No Rooted Device found !!
I am rooted and granting all access, root checker even says I am rooted. Moto X4 Diag mode say same
Old 03-25-2018, 14:07   #13 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 3,400
Originally Posted by clutchb702 View Post
-- Searching Device
-- Found
-- MODAL : moto x4
-- CPU : arm64-v8a
-- HARDWARE : qcom
What procedure you are trying if any issue we will solve it.
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post:
Old 03-25-2018, 22:28   #14 (permalink)
Member: 2721278
trying to repair imei of moto x4 but when I do the above it says this when it is clearly rooted. -- Searching Device
-- Found
-- MODAL : moto x4
-- CPU : arm64-v8a
-- HARDWARE : qcom
Old 04-04-2018, 23:21   #15 (permalink)
Member: 1019053
Thanks Meter: 2
problem repair xiaomi max 2
I have a problem with UAT, I want to write imei of a xiaomi mi max 2, qcom msm8953, but when I want to do the wipe security it gives error, it says to unlock the bootloader first, but the bootloader is unlocked, and it does not do the wipe security, the cellular is rooted and port open diag ,,, already try with tab xiaomi and with qualcomm tab and I can not, any solution? the cell phone has 2 imeis I want to repair the number 1 ,,, I hope response thanks
The Following User Says Thank You to darknees92 For This Useful Post:
Page generated in 0.19916 seconds with 7 queries
