How enable Samsung ADB with UAT? Hi. How should I connect the phone to Enable USB Debug Samsung Samsung>Utilities>Enable USB Debug Searching Device Not Found Please Check Cable or Port I can't add pics |
Make sure you have gone to settings, tapped build 7 times or so and then backed out and went into the newly created section named Developer Settings. In here select USB Debugging and watch your phone for a box to pop up. Make sure you checkmark it and hit OK. Now you can run it using UNI tool's ADB commands. |
Also youll want the adb drivers to keep and have for future use so you might google "15 second adb installer" and download that. Should be enough for you if you are just starting out. |
Waiting Mehmood... Отправлено с моего iPhone используя Tapatalk |
Hi This function for old samsung devices, 4.x.x versions, it enable by samsung usb modem port, it not work on new devices. |
I connected GT-I9300 Android 4.1.2 Searching Device Device Found Reading Info. ... Model : Software Ver. : Hardware Ver. : Serial Number : Base : PRD : Unique Number : IMEI : Conection Type : Enabling USB Debugging ... Enabling USB Debugging done ... But: -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Not Found How it works? |
https://s20.postimg.cc/qsehv7ub1/image.png Does anyone know how this works? In which mode do I need to connect the phone? |
Really the worst support, they are not answering to any questions, to help us use their tool. Fck this crap. -.- Bought this tool and had a lot of problems, and noone wants to explain how to use some parts of tool. -.- |
New Security devices are not Supported, This function was for old devices. |
How this work on old devices? Samsung GT-I9300 it’s old device. [emoji3] Отправлено с моего iPhone используя Tapatalk |
