Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 06-28-2018, 08:11   #1 (permalink)
Member: 1412935
Thanks Meter: 81
How enable Samsung ADB with UAT?
Hi. How should I connect the phone to Enable USB Debug Samsung
Samsung>Utilities>Enable USB Debug
Searching Device
Not Found
Please Check Cable or Port
I can't add pics
Old 07-01-2018, 11:55   #2 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 148
Make sure you have gone to settings, tapped build 7 times or so and then backed out and went into the newly created section named Developer Settings. In here select USB Debugging and watch your phone for a box to pop up. Make sure you checkmark it and hit OK. Now you can run it using UNI tool's ADB commands.
Old 07-01-2018, 11:56   #3 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 148
Also youll want the adb drivers to keep and have for future use so you might google "15 second adb installer" and download that. Should be enough for you if you are just starting out.
Old 07-01-2018, 12:01   #4 (permalink)
Member: 1412935
Thanks Meter: 81
I know this metod. I'm interested in something else. UAT have a tab in Samsung section - Utilities. And there is a button "Enable USB Debug". how it works? In download mode or UART?
Old 07-01-2018, 21:58   #5 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 148
Ohh.. I think that has to do with enabling adb on handsets for when removing FRP. I could be wrong though. When i did some samsung phones earlier i toyed with it but found it of no use for my operations i was executing.
Old 07-01-2018, 22:03   #6 (permalink)
Member: 1412935
Thanks Meter: 81
Waiting Mehmood...
Отправлено с моего iPhone используя Tapatalk
The Following User Says Thank You to chuikoff For This Useful Post:
Old 07-02-2018, 00:27   #7 (permalink)
Member: 311347
Sonork: 100.1672192
Thanks Meter: 486
Searching Device
Not Found
I can't add pics
Hi
This function for old samsung devices, 4.x.x versions, it enable by samsung usb modem port, it not work on new devices.
The Following 2 Users Say Thank You to gsmkolik For This Useful Post:
Old 07-02-2018, 08:24   #8 (permalink)
Member: 1412935
Thanks Meter: 81
I connected GT-I9300 Android 4.1.2
Searching Device
Device Found
Reading Info. ...
Model :
Software Ver. :
Hardware Ver. :
Serial Number :
Base :
PRD :
Unique Number :
IMEI :
Conection Type :
Enabling USB Debugging ...
Enabling USB Debugging done ...
But:
-- Checking Current Version
-- Current Version OK
-- Checking User Login
-- User Login OK.
-- Starting Adb Server : Done
-- Searching Device
-- Not Found
How it works?
Old 07-07-2018, 11:47   #9 (permalink)
Member: 1412935
Thanks Meter: 81
Does anyone know how this works? In which mode do I need to connect the phone?
Old 09-08-2018, 15:09   #10 (permalink)
Member: 2750431
Thanks Meter: 19
Really the worst support, they are not answering to any questions, to help us use their tool. Fck this crap. -.-
Bought this tool and had a lot of problems, and noone wants to explain how to use some parts of tool. -.-
Old 09-08-2018, 15:32   #11 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 10,531
New Security devices are not Supported, This function was for old devices.
Old 09-08-2018, 19:32   #12 (permalink)
Member: 1412935
Thanks Meter: 81
How this work on old devices? Samsung GT-I9300 it’s old device.
Page generated in 0.22473 seconds with 9 queries
