03-15-2024, 13:24 | #2 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : Auto detect - Process : Format | Factory Reset - Safe ==================================== Waiting for device... [COM17] Port : COM17 : MediaTek PreLoader USB VCOM (Android) USB : USB\ROOT_HUB30\4&F15BD&0&0 Initializing usb... OK Handshaking... OK Reading hardware info... BOOT MODE : PRELOADER HW ID : MT6761 [717] Helio A20/P22/A22/A25/G25 Details : CA01 , 8A00 , 0000 Sec Config : [SBA:True] [SLA:False] [DAA:True] MEID : AEBD46C816678FB486FE2A94666221C6 Sending Download-Agent (Stage-1)... OK Jump DA Address... OK Syncing... OK Getting Synchronized Signal... OK Setting Environment... OK Getting Hardware signal... OK Setting up device... OK USB_SPEED : HIGH-SPEED Connection type... [PRELOADER] Bypassing authentication (preloader auth)... OK Syncing with DA... OK Syncing with 2nd DA... OK Fetching Storage... OK CHIP TYPE : eMMC NAME : QX63AB BOOT 1 : 0x0000000000400000 [4.00 MB ] BOOT 2 : 0x0000000000400000 [4.00 MB ] RPMB : 0x0000000000400000 [4.00 MB ] STORAGE : 0x0000000747C00000 [29.12 GB ] CID : 1501005158363341420368CEBAE3C72B INIT_SRAM : 0x0000000000039000 [228.00 KB ] EXT_DRAM : 0x0000000080000000 [2.00 GB ] MEID : AEBD46C816678FB486FE2A94666221C6 HW_CODE : 0x7170000000000000 HWSUB_CODE : 0x8A00000000000000 HW_VERSION : 0xCA01000000000000 SW_VERSION : 0x0000000000000000 Reading partition info... OK [44] Reading device info... OK [Super] Android OS : Quince Tart Android Version : 10 Brand : TECNO Build : ABC-GL-220413V517 Build Date : Wed Apr 13 13:26:54 CST 2022 Build ID : QP1A.190711.020 CPU : armeabi-v7a Display ID : KE5-H6123ABC-QGo-GL-220413V517 EMI ID : ke5_h6123go Host : buildsrv-197 Local lang. : en-US Manufacturer : TECNO MOBILE LIMITED Model Name : TECNO KE5 Product Name : KE5-GL Security Patch : 2022-04-05 Soft. Version : ABC-GL-220413V517 Bootloader : LOCKED Erasing USERDATA (SAFE)... OK Rebooting device... OK UAT PRO : 164.01 | 14 - آذار - 2024 [ 11:01:21 م ] IRAQ Elapsed Time : 51 seconds 1. Power off device 2. Remove Install battery if needed 3. Connect USB cable to powered off device 4. For New sec. Press and Hold Both Volume keys for Brom Mode 5. For Old sec. Press and Hold Volume UP for Brom Mode 6. Do not press any Key for PreLoader Mode 7. Install drivers if needed ==================================== - Connection : Flash Mode - Method : Auto detect - Process : Reset FRP | Erase Method ==================================== Waiting for device... [COM17] Port : COM17 : MediaTek PreLoader USB VCOM (Android) USB : USB\ROOT_HUB30\4&F15BD&0&0 Initializing usb... OK Handshaking... OK Reading hardware info... BOOT MODE : PRELOADER HW ID : MT6761 [717] Helio A20/P22/A22/A25/G25 Details : CA01 , 8A00 , 0000 Sec Config : [SBA:True] [SLA:False] [DAA:True] MEID : AEBD46C816678FB486FE2A94666221C6 Sending Download-Agent (Stage-1)... OK Jump DA Address... OK Syncing... OK Getting Synchronized Signal... OK Setting Environment... OK Getting Hardware signal... OK Setting up device... OK USB_SPEED : HIGH-SPEED Connection type... [PRELOADER] Bypassing authentication (preloader auth)... OK Syncing with DA... OK Syncing with 2nd DA... OK Fetching Storage... OK CHIP TYPE : eMMC NAME : QX63AB BOOT 1 : 0x0000000000400000 [4.00 MB ] BOOT 2 : 0x0000000000400000 [4.00 MB ] RPMB : 0x0000000000400000 [4.00 MB ] STORAGE : 0x0000000747C00000 [29.12 GB ] CID : 1501005158363341420368CEBAE3C72B INIT_SRAM : 0x0000000000039000 [228.00 KB ] EXT_DRAM : 0x0000000080000000 [2.00 GB ] MEID : AEBD46C816678FB486FE2A94666221C6 HW_CODE : 0x7170000000000000 HWSUB_CODE : 0x8A00000000000000 HW_VERSION : 0xCA01000000000000 SW_VERSION : 0x0000000000000000 Reading partition info... OK [44] Reading device info... OK [Super] Android OS : Quince Tart Android Version : 10 Brand : TECNO Build : ABC-GL-220413V517 Build Date : Wed Apr 13 13:26:54 CST 2022 Build ID : QP1A.190711.020 CPU : armeabi-v7a Display ID : KE5-H6123ABC-QGo-GL-220413V517 EMI ID : ke5_h6123go Host : buildsrv-197 Local lang. : en-US Manufacturer : TECNO MOBILE LIMITED Model Name : TECNO KE5 Product Name : KE5-GL Security Patch : 2022-04-05 Soft. Version : ABC-GL-220413V517 Bootloader : LOCKED Resetting frp [Erase Method] : OK Rebooting device... OK UAT PRO : 164.01 | 14 - آذار - 2024 [ 10:57:01 م ] IRAQ Elapsed Time : 52 seconds |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
