07-12-2017, 17:20 | #1 (permalink) |
Insane Poster Join Date: Mar 2014
Member: 2153193 Status: Offline Thanks Meter: 11 | mi 5 account not done, in edl mode [Solved] stuck In: Analyzing Please wait ... ... either if i select "by loader method" i hope u can say me what i´m doing wrong. br. malacatonche2 Last edited by namyelus; 12-01-2017 at 14:16. |
07-12-2017, 18:07 | #3 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | Quote:
Yes you are doing wrong .. these screenshots are not from your first attempt .. when first attempt is failed you are attempting again with connected device whereas you need to disconnect device remove battery , press and hold both volume keys insert usb cable and try again. | |
07-12-2017, 21:45 | #4 (permalink) |
Member: 2153193 Status: Offline Thanks Meter: 11 | with vol + - and cable, nothing, not entry to edl model, i´m doing via test point. and the drivers are correctly installed. any advice?. when i did at first try i only get: ----- Searching device Device on Port : [ COM10 ] Analyzing Please wait ... No Response from Device Remove Battery and Re-Insert it, Hold Volume + and Volume - and insert USB Cable. ------------ Br. Malacatonche2 |
07-13-2017, 03:03 | #5 (permalink) | |
11-07-2017, 16:01 | #8 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: Surxondaryo denov
Member: 2318698 Status: Offline Thanks Meter: 15 | mi 5 account not done, in edl mode, fastboot mode, uni_android v7.02 Quote:
Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device Not Found | |
11-07-2017, 16:02 | #9 (permalink) |
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | OMG. brother Please Try on QDLoader Port not on Diagnostic Port |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
11-08-2017, 05:02 | #12 (permalink) | |
Member: 2318698 Status: Offline Thanks Meter: 15 | Thank you faster answers Quote:
12-01-2017, 13:52 | #15 (permalink) |
Member: 2318698 Status: Offline Thanks Meter: 15 | and, finally, the customer returned problem solved UNI TOOL 9.02 He finished Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM33 ] Analyzing Please wait ... CPU_ID : [MSM 8996] MEM_TYPE : UFS BLOCK_ID_S : CF059908 BLOCK_ID_L : 00000000 BLOCK_ID_H : 355D47F912FEA0AF1F46C007C6DC22C4 BLOCK_ID_H : 3544FB9359E30AA7DB5F4734D18FBD74 Starting MI Account Removal Method Reading Data .. Please wait Waiting Flash Loader to write Writting Flash Loader Waiting Flash Loader to Boot Reading MI Account Data Read data done Writting data.. Write data done Removing MI Account... MI Account Removal Succeeded. |
The Following User Says Thank You to gayrat_gsm For This Useful Post: |
