09-02-2018, 00:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | mtk tool problem i have this tool since now 9 months i never used with mtk chipset coz not detect it at all here info Checking Current Version Current Version OK Checking User Login User Login OK. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey 3. Please Connect Device within 20 Seconds. Waiting for Device After Connecting device Please wait a while ... Device not Found other tool detect and i install the drivers on support area what is the problem |
09-02-2018, 13:55 | #3 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | If you're trying to Imei Repair with UAT for instance, You need to take into consideration the following: Bootmode is not supported, you need to reboot your device into Meta-mode. The latter necessitates CDC Drivers. Here is attached a short tutorial on how to proceed with CDC drivers installation..... https://androidmtk.com/install-andro...river-manually Good luck |
09-02-2018, 14:14 | #5 (permalink) | |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Quote:
no not imei problem it is hang on logo and after flashing with nck it is ok and imei is invalid also repaired with meta mode by nck uat not detect mtk | |
