09-24-2019, 17:45 | #1 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2503294 Status: Offline Thanks Meter: 1 | P20 lite FRP error, please HELP UAT FRP Module Searching Device ... Device Found Selected device : P20 Lite LX1 Device : Huawei Model : HUAWEI Mate 20 lite Sending Data to device, Please wait... Data Successfully Sent. Waiting for User Action... Please Wait if Any Drivers Installation is in Process. Waiting for Device to be Online... Freeze here.... Can you help me? |
The Following User Says Thank You to inlutec For This Useful Post: |
10-23-2019, 12:11 | #2 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Tunisia Sidi Bouzid
Member: 104737 Status: Offline Thanks Meter: 76 | Quote:
Any solution plz | |
10-23-2019, 14:21 | #4 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Canada
Member: 2689153 Status: Offline Thanks Meter: 45 | Mmm I think this is not a problem of adb drivers For team I have tried several devices in this module and in modern versions of Android it is not able to activate adb, it only worked on 2 devices (Android 7) of 15 that I tried and with another tool they worked 12 of those same 15 phones by fastboot the other 3 had to work with board software .Xml After removing the frp and activating the adb from the uat menu you can read it normally For user: The newest models such as the huawei mate 20 lite, p20 lite, p20, p20 pro etc are worked by test point either direct frp by test point or load board software and then stock software, however there is also the option of frp key, it is a password that you enter with a fastboot command and this eliminates the frp |
10-23-2019, 14:22 | #5 (permalink) |
Member: 2689153 Status: Offline Thanks Meter: 45 | The team would be so kind to explain under what conditions does the frp huawei work? Because apparently it is not a universal method like frp fastboot, do you need an android version or specific security patch? Or how does it work? |
