12-15-2018, 19:34 | #1 (permalink) |
Junior Member Join Date: Sep 2015 Location: Tunisia
Member: 2456608 Status: Offline Thanks Meter: 0 | Problem unlock galaxy s4 GT-I9505 [SOLVED] phone rooted i choose DM+Modem+ADB android 5.0.1 -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. 1 - Dial *#0808# Chose DM+Modem+ADB 2 - Connect Usb cable and Install Driver if need 3 - Select Samsung Serial port and click unlock Button if Device Android Version 5.x.x or Higher then 1 - Root the device 2 - Connect usb cable and enable usb debbug 3 - Going to Samsung Tab -> Utilities -> Click Enable Diag Button 4 - Dial *#0808# Chose DM+Modem+ADB 5 - Select Samsung Serial port and click unlock Button Searching Device Device Found Selected Port : COM11 [ Port 921600] Unlock Process Started .. Reading Phone Information ... Relase Date : Compile Date : Build No : |
12-16-2018, 14:32 | #3 (permalink) |
Member: 2456608 Status: Offline Thanks Meter: 0 | Unlock... FAILED -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. 1 - Dial *#0808# Chose DM+Modem+ADB 2 - Connect Usb cable and Install Driver if need 3 - Select Samsung Serial port and click unlock Button if Device Android Version 5.x.x or Higher then 1 - Root the device 2 - Connect usb cable and enable usb debbug 3 - Going to Samsung Tab -> Utilities -> Click Enable Diag Button 4 - Dial *#0808# Chose DM+Modem+ADB 5 - Select Samsung Serial port and click unlock Button Searching Device Device Found Selected Port : COM37 [ Port 921600] Unlock Process Started .. Reading Phone Information ... Relase Date : Compile Date : Build No : IMEI : 000000000000000 ESN : 7E Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Analizing Security... OK -> New Security Detected! Unlocking Device Unlock... FAILED |
12-16-2018, 17:24 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Turkey Age: 39
Member: 311347 Status: Offline Sonork: 100.1672192 Thanks Meter: 486 | Quote:
New Security Not supported, need downgrade modem. | |
