10-28-2017, 15:29 | #4 (permalink) |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | Please Read Instructions .. Turn off phone press and Hold both volume keys and insert cable install QDLoader drivers if needed .. if still your device is not detected on 9008 port then use Deep EDL Cable and if on this cable also not detects 9008 Port then use Test Point Method. |
10-29-2017, 13:01 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | The thing is : I got 2 identical phone : Ucall Miami. One is bricked and when connected to pc, it`s detected as 9008. The other one is perfectly functioning, I can activate DIAG using ADB and it`s detected as 9008, even when I try to manually force driver as 9008. Tried with volume + - and insert cable, phone is also detected as 9006. Phone has no test point on motherboard to activate 9008. |
10-29-2017, 13:58 | #9 (permalink) | |
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | Quote:
As Already request to Post Latest version UAT screen shot .. you will be properly helped otherwise thread will be closed. | |
