09-12-2018, 20:59 | #1 (permalink) |
Registered User Join Date: Apr 2007
Member: 484250 Status: Offline Thanks Meter: 21 | UAT FRP Huawei P20 (and other devices) when I connect any Huawei device (P20 now) there are installed these ports: And the UAT doesn't recognize it so I cannot unlock the device. What's the problem please? |
09-13-2018, 08:41 | #2 (permalink) |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Hello, Sorry We're not understand your excatlly question, if you want unlock FRP then Install HiSuite and in UAT FRP Pack Reset FRP again. BR |
09-13-2018, 08:55 | #3 (permalink) | |
Member: 484250 Status: Offline Thanks Meter: 21 | Quote:
OK again step by step: 1. I connected the device in the MTP mode HiSuite is installed - no problems with drivers) 2. Choose right model and click Reset FRP 3. Device was recognized and "patched" 4. I rebooted device and connected to the PC - all drivers were installed correctly (according to picture above) but the UAT doesn't recognize the phone! Unfortunately when I connect the device again it connects in this "patched" state and there is no chance how to connect it again. | |
09-13-2018, 09:31 | #4 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,540 | Quote:
After Patching when you reboot device , Check Adb drivers are Installed or not. If device is patched then after reboot you can simply use ADB Frp. | |
09-13-2018, 09:46 | #5 (permalink) | |
It would be great but I can NOT because the device is unauthorized the confirmation window for the authorization doesn't appear - tested with many devices and it is still same. | |
09-13-2018, 10:01 | #6 (permalink) | |
when UAT ask you to reboot device, and after reboot if device adb authorization failed or authorization window not appears on device screen. use adb directory and use cmd window with adb commands adb kill-server and adb start-server, hopefully these commands will revoke adb authorization in your device. if done then use adb frp. | |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
