03-06-2018, 22:44 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | asus senfone 4 max not repair imei Searching Device Devie Found !! Selected Port : COM70 Reading Device Info. Compile Date : Release Date : Model ID : Build ID : MEID : 000D0000001000 IMEI : 1000000D0000000 ESN : 00001000 Device : Qualcomm New IMEI : xxxxxxxxxxxxxxxx New IMEI 2 : xxxxxxxxxxxxxxxxxxxxx Writting IMEI ... Please Wait ... Writting IMEI 1 Sucessful!! Writting IMEI 2 Sucessful!! Rebooting Device If it does not Auto Reboot Please Reboot it Manually, do not Remove Battery. Elapsed Time : 0 minutes - 3 seconds br treo29 |
03-06-2018, 22:47 | #2 (permalink) |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Hello, You are trying at EDL Mode Repair IMEI, First download test firmware of your device from Support Area, This rom Diag enabled and Rooted, after flashing Select diag port then repair imei, After Repair imei Flashing stock rom. BR |
The Following User Says Thank You to namyelus For This Useful Post: |
03-06-2018, 23:24 | #3 (permalink) |
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | at the time of flashing error -- Device Found -- Reading Device Info. -- Version : 0.5 -- Product : QC_REFE -- Serial No : 4915c29e -- Flash Process Started -- Download Size : 535822336 bytes -- sending sparse zip (523260 KB) -- Verifying : OK -- writing zip -- Verifying : Failed -- Partition flashing is not allowed ====================================== -- Flash Process Completed -- Rebooting Device -- Elapsed Time : 0 minutes - 21 seconds br treo29 |
03-07-2018, 09:29 | #4 (permalink) | |
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Quote:
Hello, Please unzip file, and run flash_all.bat file. BR | |
