11-20-2017, 21:57 | #3 (permalink) |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Hello, its should enable ADB, Please install ADB Drivers and at FRP Tab using Samsung ADB Method....then will bypass frp and enable oem lock then factory reset. BR |
11-21-2017, 09:25 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | I do have ADB installed... obviously Tablet connected in Fastboot ..... right ? So it`s not recognised Last edited by tintome; 11-21-2017 at 09:33. |
11-21-2017, 09:36 | #6 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,509 | Quote: Sir, will you please check what are you doing, device is in fastboot and you are performing adb operation, obviously result is expected what you are getting. Contact me on Skype I will guide you how these operation happens. Skype ID : Mehmood Riaz | |
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post: |
12-16-2017, 12:52 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 269 | Works perfect for me! android 7.0 just select ASUS, activate adb with method 2 and after use any bypass by abd method! br ss |
The Following User Says Thank You to agentot For This Useful Post: |
02-04-2018, 18:26 | #9 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Romania
Member: 311520 Status: Offline Thanks Meter: 6 | Checking Current Version Current Version OK Checking User Login User Login OK. Searching Device - Fastboot Device Found -- Reading Device Info. -- Version : 0.5 -- Product : ASUS8163_EW_380 -- Serial No : Sending Data : Done Executing Exploit : Done Enabling Adb : Done Please Check device screen Allow Adb Authorization if Prompted. Elapsed Time : 0 minutes - 1 seconds |
