Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 10-22-2018, 19:02   #46 (permalink)
Member: 2477800
Thanks Meter: 5
need login info please. lost password
Old 10-22-2018, 22:03   #47 (permalink)
teokarafou's Avatar
Member: 2578145
Thanks Meter: 116
you release a update ,this is what you call a update?????
UAT Team please be serious,we are not doing this job for hobby
Old 10-22-2018, 22:55   #48 (permalink)
Member: 88609
Thanks Meter: 45
Searching Device ... [Download Mode]
Error : No Device Found.
Old 10-22-2018, 23:36   #49 (permalink)
Flash0r's Avatar
Member: 96012
Thanks Meter: 6
Originally Posted by Mehmood Riaz 1 View Post
Please wait for next update.
when will this be?
i have the same problem
Old 10-23-2018, 07:05   #50 (permalink)
Registered User
Member: 537781
Thanks Meter: 20
bro new update is not good plz fix it urgent thanx
Old 10-23-2018, 13:36   #51 (permalink)
Member: 1090266
Thanks Meter: 22
Sm-g550fy frp
Samsung On5 Pro SM-G550FY FRP
Hello Team Fix This bug....No Device Found .....
Old 10-23-2018, 13:51   #52 (permalink)
Member: 2647406
Thanks Meter: 52
Searching Device ... [ADB Mode]
Found
MODAL : BTV-DL09
MANUFUCTURER : HUAWEI
ANDROID VERSION : 7.0
CPU : arm64-v8a
HARDWARE : hi3650
BOARD : BEETHOVEN
BOOTLOADER : unknown
USB CONFIG : manufacture,adb
USER : test
BASEBAND : 21.258.09.00.030
DISPLAY ID : BTV-DL09C233B362
BUILD ID : HUAWEIBEETHOVEN-DL09
REGION : CN
LANGUAGE : zh
SIM STATE : ABSENT
BUILD DATE : Mon Jul 2 02:24:13 CST 2018
BUILD TAGS : release-keys
NETWORK TYPE : UMTS
SIM OPERATOR :
LCD DENSITY : 480
Checking Root : Not Rooted
Bypassing Huawei ID Please wait...
Bypass Successfully done
Rebooting device
But never get remove huawei ID
Old 10-23-2018, 15:14   #53 (permalink)
Member: 2311393
Thanks Meter: 12
Could you please kindly point where are the Testpoint pictures for the Xiaomi devices?
Old 10-23-2018, 18:20   #54 (permalink)
Member: 2718408
Thanks Meter: 4
The problem of having two different IDs still persists even after installing the new update ...
Any solution?
Old 10-23-2018, 18:29   #55 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Any solution?
Download/install NEW update 9.0.1, all working fine, no issue with ID, are the same.
Old 10-23-2018, 18:31   #56 (permalink)
Member: 2779485
Please Kyocera C6743 FRP
Checking Current Version
Current Version OK
Checking User Login
User Login OK.
Searching device
Device on Port : [ COM6 ]
Analyzing Please wait ...
CPU_ID : [MSM 8909]
MEM_TYPE : EMMC
BLOCK_ID_S : 060C81CD
BLOCK_ID_L : 00000000
BLOCK_ID_H : 7BE49B72F9E4337223CCB84D6ECCCA4E
BLOCK_ID_H : 61CE16E3602AC2008CB18B75BABE6D09
Starting Qualcomm Frp Removal Method
Reading Data .. Please wait
Sending loader Please wait ...
Failed to start programmer.
Page generated in 0.20647 seconds with 10 queries
