Everything will be back just in 2-3 updates, We will try to make it much more strong Tool. |
SPD Update Quote:
Thank for thinking make "Strong Tool" in GSM market. I hope add some Spreadtrum Features. |
Oppo a3s frp support |
Uat 20.01 some error 1 sm-g600fy frp error ( old version working) 2 how to frp remove sm-j210f( old version support samsung -new methed) 3 asus flasher nill br, shameer |
. Lenovo x3a40 vipe,flash not working other tool ok. Searching Device ... Device on Port : [COM10] Analyzing Please wait ... MSM_ID : [MSM 8992] MEM_TYPE : eMMC HW_ID : 009690E1 BLOCK_ID_S : 01943C8B BLOCK_ID_H : 99C8C13E374C34D8F9AFB065EA4C733E BLOCK_ID_H : 6B1B21CBC5A78705F041EB24ACDD5FE5 Sending Loader Please wait... Writting Loader Successfully! Reading Partition Table... Read Partition Table Failed!! |
Nice good job uni android tool |
Hello, Please repeat process when get this error. BR |
At the end update released....good work UAT Team :) |
Report Flash Qualcomm Fail https://lh4.googleusercontent.com/RE...=w1366-h657-rw Backup Security , Read info ok but save file failed, security backup 0 bytes https://lh6.googleusercontent.com/jF...=w1366-h657-rw List partisi ok, backup selected file save ok https://lh5.googleusercontent.com/fU...=w1366-h657-rw |
Please kinldy fix bugs roundabout all not working i try many difrrent models not working thanks |
Thanks a lot for reports, we will check 2nd image issue , as far as flashing is concerned it is not flasher issue it is the loader issue which you are using. |
Searching Device ... Device on Port : [COM10] Analyzing Please wait ... HW_ID : 009690E1 BLOCK_ID_S : 01943C8B BLOCK_ID_H : 99C8C13E374C34D8F9AFB065EA4C733E BLOCK_ID_H : 6B1B21CBC5A78705F041EB24ACDD5FE5 Sending Loader Please wait... Writting Loader Successfully! Reading Partition Table... Read Partition Table Failed!! Lenovo model x3a40 tab Searching Device ... Device on Port : [COM10] Analyzing Please wait ... HW_ID : 009690E1 BLOCK_ID_S : 01943C8B BLOCK_ID_H : 99C8C13E374C34D8F9AFB065EA4C733E BLOCK_ID_H : 6B1B21CBC5A78705F041EB24ACDD5FE5 Sending Loader Please wait... Writting Loader Successfully! Reading Partition Table... Read Partition Table Failed!! Infinity box Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1.Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 808 [MSM8992] ID_BLOCK_S : 01943C8B ID_BLOCK_L : 4D1110EAEE98EB3C41626A86359CBFE6 ID_BLOCK_L : B6F9FB16277A6FE8319708C844048A04 Use CM2 Internal Loader Loader Sent!Initializing ... Running FireHose on BBID : MSM8992 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00000400/00001000/00000200 Boot Ok! Brand : Lenovo ProdName : x3_row ProdModel : Lenovo X3a40 Device : x3_row AndroidVer: 5.1.1 Manufact. : LENOVO SysPatch : LMY47V DevComTime: 22.11.2015 3:09:36 QLMxCPU : MSM899 2 QLMxPRJ : X3a40_USR_S130_1511221039_Q00077_ROW USERData : NORMAL GC Sec : NORMAL Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
It is not possible to check huge list of each device .. if this happens with any particular device then ignore it but if it happens with each device then we will check it and fix it. |
