Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT
Old 01-12-2019, 12:28   #31 (permalink)
Member: 1719788
i try to bypass mi accound on redmi 5 plus and i get not enough space on disk
Old 01-12-2019, 12:33   #32 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
Truly not understand by not enough space on disk, you must make free some space in your C part of hard drive.
Old 01-12-2019, 12:40   #33 (permalink)
Member: 1726210
Thanks Meter: 21
samsung efs reset option not working
Old 01-12-2019, 12:41   #34 (permalink)
Member: 1719788
maybe this is more explicit with not enough,i cannot post link
imgur .com/a/McfyNpg
Old 01-12-2019, 12:50   #35 (permalink)
Member: 85100
Thanks Meter: 11
Originally Posted by Mehmood Riaz 1 View Post
It is not possible to check huge list of each device .. if this happens with any particular device then ignore it but if it happens with each device then we will check it and fix it.
No device problem.Problem is qualcom tab.Other device same problem
ID_BLOCK_I : SnapDragon 430 [MSM8937]
ID_BLOCK_S : C19F0EBA
ID_BLOCK_E : 00007A2A
ID_BLOCK_L : 9AC0C13D3F4F3ACB1E53B977E4B38839
ID_BLOCK_L : 83F6C423284F74FD3CA005D35F39BF09
Searching Device ...
Device on Port : [COM10]
Analyzing Please wait ...
HW_ID : 0004F0E1
BLOCK_ID_S : C19F0EBA
BLOCK_ID_H : 99C8C13E374C34D8F9AFB065EA4C733E
BLOCK_ID_H : 6B1B21CBC5A78705F041EB24ACDD5FE5
Sending Loader Please wait...
Writting Loader Successfully!
Reading Partition Table...
Read Partition Table Failed!!
Old 01-12-2019, 12:54   #36 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
What error you get , please post screenshot so that can be fixed
Old 01-12-2019, 13:15   #37 (permalink)
Member: 1636876
Thanks Meter: 9
this updateis remove mi flash tool , asus flash tool remove and adb info and frp,
i hope add nest update
Old 01-12-2019, 13:16   #38 (permalink)
Crazy Poster
Member: 2227538
Thanks Meter: 14
support site showing virus...
Old 01-12-2019, 13:22   #39 (permalink)
Crazy Poster
Member: 2227538
Thanks Meter: 14
in latest version, there is no adb flasher(sideload)...
The Following User Says Thank You to raj_333 For This Useful Post:
Old 01-12-2019, 14:14   #40 (permalink)
Member: 1372118
Thanks Meter: 116
Thanks a lot for reports, we will check 2nd image issue , as far as flashing is concerned it is not flasher issue it is the loader issue which you are using.
loader is correct
read info partition list ok but flash failed
i use same loader
Old 01-12-2019, 14:25   #41 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
Originally Posted by MVNDOzone View Post
loader is correct
i use same loader
Will you please try by using Manual Flash Method.
Old 01-12-2019, 14:45   #42 (permalink)
Member: 1662156
Thanks Meter: 4
Good congratulation Team uniandroidtool
Old 01-12-2019, 14:46   #43 (permalink)
Member: 1524998
Thanks Meter: 59
and now the options in adb wifi repair, root sideload, etc do not exist
Old 01-12-2019, 15:01   #44 (permalink)
Mr_F10ch3's Avatar
Member: 469532
Thanks Meter: 817
Great, long time waiting for new update, and awesome UI update...
Old 01-12-2019, 15:05   #45 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
We will put everything back in just few upcoming Updates.
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post:
Page generated in 0.14332 seconds with 7 queries
