Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT
Old 01-12-2019, 15:56   #46 (permalink)
Member: 1719788
qulacomm tab, xiaomi bypass mi account error : exception EOSError in module Uni-Android .exe at 00030DED. System Error. Code : 112 . Not enough space on the disk.
I have space on C and other partition at least 30GB free.
Old 01-12-2019, 16:05   #47 (permalink)
Member: 1265180
Sonork: 9010179292
where is flashing option in xiomi
Old 01-12-2019, 16:52   #48 (permalink)
Member: 2770425
Thanks Meter: 9
With this update I get this error. Access violation at address 5370957E in modulelibhogweed-4.dll. Read of address 00000000
The Following User Says Thank You to Raffy0411 For This Useful Post:
Old 01-12-2019, 17:03   #49 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
Please check in Tool Folder libhogweed-4.dll is present or not .. If it is there then your System might be infected which does not allow this dll to execute.
Old 01-12-2019, 17:08   #50 (permalink)
Member: 2770425
Thanks Meter: 9
If the libhogweed-4.dll file is present, what should I do?
Old 01-12-2019, 17:16   #51 (permalink)
Member: 2770425
Thanks Meter: 9
Old 01-12-2019, 17:18   #52 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
what is the size of dll file ?
Old 01-12-2019, 17:28   #53 (permalink)
Member: 2770425
Thanks Meter: 9
the size is 9,051 KB
Old 01-12-2019, 17:30   #54 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
File is OK, Please scan your System for any viruses.
Old 01-12-2019, 17:31   #55 (permalink)
Member: 2063130
Thanks Meter: 87
All function worked fine. Thenks team
Old 01-12-2019, 17:50   #56 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 130
UAT support please where is the ADB option in new update?
Old 01-12-2019, 17:53   #57 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
Sir, I said in reply of each such Posts that every function which is missing will be back in upcoming updates.
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post:
Old 01-12-2019, 18:28   #58 (permalink)
Member: 2770425
Thanks Meter: 9
After a scan with the antivirus, some problems were solved and I can start the program. Thank you
Old 01-12-2019, 19:16   #59 (permalink)
benypavon's Avatar
Member: 1835486
Thanks Meter: 25
Bad version , errors, erros, errors, Innestable
no flash ZTE qualcomm
Old 01-12-2019, 20:25   #60 (permalink)
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 5,102
Not a bad version, we have already tested ZTE Flashing before release.
using error error will not solve the issue you need to post whole details with error screen shot if any issue will be checked.
Page generated in 0.28279 seconds with 7 queries
