Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Uni-Android Tool - UAT PRO
Old 10-24-2017, 06:13   #46 (permalink)
Registered User
Member: 2770326
Sonork: 100.1679137
Thanks Meter: 3
Great Update
Nice update...........plz add scure boot and moto frp latest patch
Old 10-24-2017, 07:33   #47 (permalink)
Registered User
Member: 2770326
Sonork: 100.1679137
Thanks Meter: 3
Please add secure boot mtk and latest patch moto frp .............
Old 10-24-2017, 07:33   #48 (permalink)
Member: 380370
Sonork: 1601470
Thanks Meter: 52
@Namyelus X sir
If we have Other model .boot file can we unlock it with UAT..
Like j710..J510,etcc
Old 10-24-2017, 07:44   #49 (permalink)
Mehmood Riaz 1's Avatar
Member: 1737175
Sonork: 100.1667675
Thanks Meter: 10,530
Instead of asking such Questions .. There is already Instructions given in the Tool for these process.
The Following User Says Thank You to Mehmood Riaz 1 For This Useful Post:
Old 10-24-2017, 09:18   #50 (permalink)
Member: 1393932
Thanks Meter: 4
hello technitions, i try to find solution for LG-D958 (G-FLEX) , after flashing network gone, its only show emergence then says 'service disabled' how cane i solve this problem? cause i try to change many different firmware/repair/unlock and etc.. but the same problems.
this tool cane solve my this problem?
Old 10-24-2017, 09:21   #51 (permalink)
Member: 592636
Thanks Meter: 674
hi boss
in this process need to checking version boot files same as version in the phones?
thanks
Old 10-24-2017, 09:24   #52 (permalink)
namyelus's Avatar
Member: 2709688
Thanks Meter: 2,186
Originally Posted by waseem pirmahal View Post
Kernal maker boot.img can remove "Reset Locks" if FRP on locked bootloder Samsung Devices or not ?
Hello,
No, its not work on locked bl and Factory reset protection block on.
Old 10-24-2017, 09:28   #53 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
is this necessary to make boot file from same version on phone or downgrade or upgrade versions work also?.Like phone have binary 2 version and i have binary version 1 boot file is that work for me.
Old 10-24-2017, 09:32   #54 (permalink)
namyelus's Avatar
Member: 2709688
Thanks Meter: 2,186
Hello, No it will not work, you will need write same or higher boot.
The Following User Says Thank You to namyelus For This Useful Post:
Old 10-24-2017, 13:02   #55 (permalink)
subeesh1987's Avatar
Member: 940655
Sonork: 1587842
Thanks Meter: 44
does it support frp enabled handsets for lock reset without data loss ?????
Old 10-24-2017, 13:07   #56 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
http://forum.gsmhosting.com/vbb/12747155-post52.html
Old 10-24-2017, 13:22   #57 (permalink)
Member: 1727968
Sonork: ngonie
Thanks Meter: 42
is your phone cdma or gsm
try to check if the phone in not cdma when you are inserting a gsm sim card (2) check your imei . 3 is it not network locked . if the three are working check your antena if it fails then flash nv data .
Old 10-24-2017, 14:46   #58 (permalink)
Member: 2744335
good update from good time ✅
Old 10-24-2017, 17:25   #59 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
Thanks Meter: 50
this update ...can remove lock with kernel .remove lock without loss date ....frp on ....plz answer
Old 10-24-2017, 17:26   #60 (permalink)
Member: 2758082
Sonork: gmail.com
por favor como podria leer la flash de un mtk con este programa tan bueno
Page generated in 0.23733 seconds with 9 queries
