11-20-2017, 19:29 | #48 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1709150 Status: Offline Thanks Meter: 2 | You answered in post 38 that S6 was supported without root, I have now purchased the product but the software will not find my SM-G925F when I try to unlock even though the com port is active. Would you be kind enough to give instructions on how unlock is achieved? USB debugging is active. Any suggestion gratefully received. |
11-20-2017, 20:13 | #49 (permalink) | |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Quote:
1 - Select Model 2 - Connect Device at regular mode 3 - Select Modem port and Click Direct Unlock BR | |
11-20-2017, 23:32 | #50 (permalink) |
Member: 1709150 Status: Offline Thanks Meter: 2 | Thanks for the reply, I had put the phone in download mode. Seems I will have to downgrade to Lollipop to unlock so I will have another go tomorrow. Once again many thanks for your reply. |
11-21-2017, 08:59 | #51 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | thanks but did not work ..maybe i missing one step..ive 2 x s6 at hand like now same error,,all rooted....my prob is this on same fones if i execute reset FRP ufs all working correct but on cert writing phone not detected ...am using z3x as interface..i try enable uart via usb and com..not working...on sone fones like j500 and e700 cables and interface working..am i missing another step on g925F or is it supported????/ |
11-21-2017, 23:22 | #52 (permalink) | |
Put device to test mode for detect, *#0*# then connect uart again and try again. BR | |
11-22-2017, 11:12 | #54 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Zanzibar
Member: 845667 Status: Offline Thanks Meter: 40 | I need help Uni 9.01 i face some problem when i want to work This error YOU ARE USING UAT FIRST TIME pls close and Re-open it i do but sometime ok and some time repeated. pls |
11-23-2017, 12:51 | #58 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,531 | Quote:
Link is absolutely working UAT_Setup_9.01 | |
