06-28-2018, 08:11 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Russia
Member: 1412935 Status: Offline Thanks Meter: 81 | How enable Samsung ADB with UAT? Samsung>Utilities>Enable USB Debug Searching Device Not Found Please Check Cable or Port I can't add pics |
07-01-2018, 11:55 | #2 (permalink) |
Freak Poster Join Date: Jun 2018 Location: Internetz Age: 40
Member: 2843734 Status: Offline Thanks Meter: 148 | Make sure you have gone to settings, tapped build 7 times or so and then backed out and went into the newly created section named Developer Settings. In here select USB Debugging and watch your phone for a box to pop up. Make sure you checkmark it and hit OK. Now you can run it using UNI tool's ADB commands. |
07-01-2018, 11:56 | #3 (permalink) |
Member: 2843734 Status: Offline Thanks Meter: 148 | Also youll want the adb drivers to keep and have for future use so you might google "15 second adb installer" and download that. Should be enough for you if you are just starting out. |
07-01-2018, 12:01 | #4 (permalink) | |
Member: 1412935 Status: Offline Thanks Meter: 81 | Quote:
07-01-2018, 21:58 | #5 (permalink) |
Member: 2843734 Status: Offline Thanks Meter: 148 | Ohh.. I think that has to do with enabling adb on handsets for when removing FRP. I could be wrong though. When i did some samsung phones earlier i toyed with it but found it of no use for my operations i was executing. |
07-02-2018, 00:27 | #7 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Turkey Age: 39
Member: 311347 Status: Offline Sonork: 100.1672192 Thanks Meter: 486 | Quote:
Hi This function for old samsung devices, 4.x.x versions, it enable by samsung usb modem port, it not work on new devices. | |
The Following 2 Users Say Thank You to gsmkolik For This Useful Post: |
07-02-2018, 08:24 | #8 (permalink) |
Member: 1412935 Status: Offline Thanks Meter: 81 | I connected GT-I9300 Android 4.1.2 Searching Device Device Found Reading Info. ... Model : Software Ver. : Hardware Ver. : Serial Number : Base : PRD : Unique Number : IMEI : Conection Type : Enabling USB Debugging ... Enabling USB Debugging done ... But: -- Checking Current Version -- Current Version OK -- Checking User Login -- User Login OK. -- Starting Adb Server : Done -- Searching Device -- Not Found How it works? |
09-08-2018, 15:09 | #10 (permalink) |
Insane Poster Join Date: Aug 2017
Member: 2750431 Status: Offline Thanks Meter: 19 | Really the worst support, they are not answering to any questions, to help us use their tool. Fck this crap. -.- Bought this tool and had a lot of problems, and noone wants to explain how to use some parts of tool. -.- |
