Who facing this Error ! Access violation at address http://www.photo-host.org/images/2018/01/05/zvDYwp9.png http://i64.tinypic.com/24e6t1x.jpg All the user who are facing access violation error , Please follow these steps 1. Right click on Tool , Open Properties , Select Compatibility Tab 2. Click on Change setting for all users Button 3. Tick Run this Program in Compatibility mode for : 4. if you are using Win 7 Select Win 7 5. If you are using win 10 Select win8 6. Select Run this Program as Administrator and Apply |
same errror coming--------------------------------- |
Run application as administrator |
Same error.... How to fix pleseeeeee |
Ayuda ami tambin sale lo mismo antes reiniciaba la laptop 3 a 5 veces y servia mientras no cierre el programa, ahora lo instalo lo desistan lo, reinicio pc y nada, |
hi same error .i close and open it again to solved. |
hi I have problem with login but not that error check error 02DEE1D4--------Read address 00000340 pls i need help 2weaks left problem to day this error tomorrow new error number pls what is m y problem ? |
error solved by few setting in my laptop need to check in other pc or laptop Hi to all me also face this error in new version me using win7 64bit os http://i64.tinypic.com/2r3uvck.jpg after try few setting my problem solved now http://i64.tinypic.com/24e6t1x.jpg working http://i66.tinypic.com/2isz4mw.jpg check this setting & tel work or not thx br akk.vpm |
It presents the same problem on my pc and is not solved with the process described above |
After following all steps I still have same problem access violation. How to solve this? |
help error access violations 02DEE1D4 when trying to start uni android tol help to solve the problem some administrator or someone answering me please I can not use the tool for the error help:confused: |
I’ve the same problem each time I restart the computer. Sent from my iPhone using Tapatalk |
My solution for now is to close the program am reopen it again an it works fine. [emoji1474] Sent from my iPhone using Tapatalk |
