05-17-2019, 02:18 | #3 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | already done upgrade mode manually team,. same thing, cannot detect device in upgrade mode,. when i try other version, there is no adapter port on device manager,. that version only came with adapter port but still not detected,.. |
05-20-2019, 19:31 | #4 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: neighborhood
Member: 1097964 Status: Offline Thanks Meter: 157 | Quote:
and only install hisuite disconnect phone when show error connect phone again and press retry | |
The Following User Says Thank You to mutahhar For This Useful Post: |
05-26-2019, 03:31 | #5 (permalink) | |
Member: 665025 Status: Offline Thanks Meter: 44 | Quote:
hisuite and hdetool only installed same result bro,. reconnect, same can't find device on upgrade mode,. any other solution pls,..................... | |
05-30-2019, 16:58 | #11 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | In below link find full "Update.app" and "Custom file" you can see becouse file more small size is the Custom File. DOWNLOAD But you issue is in Drivers or ceck Battery, (must be at 50/60% of charge), if is broken replace this and retry. |
