Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HDE Tool
Old 03-15-2018, 17:44   #1 (permalink)
Hua Supporter's Avatar
Member: 2179353
Thanks Meter: 14,671
Wink HDE TOOL 242 Fix and Flasher Version 0.51 Released
HDE Tool Version 1.0.242 Fix and HDE FLASEHR Version 0.51 Released
Super
professional
Tool
For
Huawei
Phones
The Best HUAWEI Tool in World
WHAT YOU NEED FOR HUAWEI AGAIN??!!!!!
DIRECT UNLOCK : SUPPORTED
IMEI REPAIR : SUPPORTED
ERASE FRP AND HUAWEI ID : SUPPORTED
READ BOOTLOADER CODE : SUPPORTED
REPAIR NETWORK : SUPPORTED
REPAIR AS EMPTY BOARD (AFTER CHANGE EMMC IC) : SUPPORTED
ENABLE ALL LANGUAGE
: SUPPORTED
FULL SERVICE : SUPPORTED
Add
NEW Factory Files
and
APP to Flasher File Support
and
bug fixes and improvements
Fix
HDE SERVER Connection Problem.
DOWNLOAD
HUA TEAM
The Following 8 Users Say Thank You to Hua Supporter For This Useful Post:
Old 03-15-2018, 18:05   #2 (permalink)
Member: 2108610
Thanks Meter: 181
NEW Factory Files????
and
APP to Flasher File Support ??? What is?? What is the new???
Old 03-15-2018, 18:09   #3 (permalink)
Member: 2179353
and
board software for some old models(user request)
update.app for new models
fix this problem too
you have problem?
The Following User Says Thank You to Hua Supporter For This Useful Post:
Old 03-15-2018, 18:13   #4 (permalink)
Member: 2108610
Thanks Meter: 181
This version support flash Update.App old models Qualcomm Hisilicon MTK????
Old 03-15-2018, 18:23   #5 (permalink)
Member: 2179353
please buy hde and then send comment here.
ABOUT HDE + FLASHER
www.huadongle.ir/hde
Old 03-15-2018, 18:45   #6 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,001
Hello.
Thankx fot frequenly Update.
This morning i have find other Autoinstaller for this version, so no need i use this download?
Other thing, have Flashed "Huawei Qualcomm Y550-L02" but always Failed, then have search the "Board" for this model but Not there's in support area, (i've thinked HW problem).
At the end, same Firmware have flashed with Sd Card, Phone Succesfully Repaired, so what's the problem with this Qualcomm? 3 time Flash Failed.
Sorry for long post, but should have a answer please.
P.D. I've the HDE version 244 now, first of this update, need of install this 1.0.242??
The Following User Says Thank You to allumts For This Useful Post:
Old 03-15-2018, 18:47   #7 (permalink)
Digital EDGE's Avatar
Member: 1240161
Thanks Meter: 92
How much would it cost to upgrade Hau Tool to Hua Pro?
Old 03-15-2018, 18:57   #8 (permalink)
Member: 2179353
you must buy hde tool
hua pro is just for new users.
Old 03-15-2018, 18:58   #9 (permalink)
Member: 2179353
Originally Posted by allumts View Post
Hello.
Y550-L01_V100R001C00B258_Board Software_inc_testpoint.dgtks
write this file with 9008 port and then flash update.app
Can use any Board software for any model version. For example Y550-L01 Board software fits all Y550-Lxx versions etc.,same for other phones
Repair dead boot huawei qualcomm with hde(video)
HDE DRIVER IS NOT SAME WITH HQT/CM2
NEED DOWNLOAD AGAIN
Upgrade mode on HDE FLASHER is same with sd card update
The Following 3 Users Say Thank You to Hua Supporter For This Useful Post:
Old 03-15-2018, 19:16   #10 (permalink)
allumts's Avatar
Member: 1564612
Thanks for all detailed answer, all installed and full working.
Only this hasn't worked today
50 phone flashed and alone all was switching from Fastboot to Upgrade mode, this Y550-L02 Not have switched from Fastboot to Upgrade mode, (phone was only stuck in Fastboot), why?
Old 03-15-2018, 19:20   #11 (permalink)
Member: 2179353
You must write board software(9008 mode)then upgrade mode for this model(no need fastboot)
Old 03-15-2018, 19:30   #12 (permalink)
allumts's Avatar
Member: 1564612
Ok, i've tryed in Sd Card mode and phone Full working, (no need of 9008 mode), with same "update.app" that had tryed with HDE Flasher.
Phone HW was perfect, only have want the "Upgrade Mode", Full repaired
The Following 3 Users Say Thank You to allumts For This Useful Post:
Old 03-16-2018, 11:20   #13 (permalink)
Member: 1443647
Thanks Meter: 2
If i actvate hua in my cm2 , can i get hde tool???
Old 03-16-2018, 11:41   #14 (permalink)
Member: 2179353
You must buy hde for use.
No need dongle
Old 03-16-2018, 11:44   #15 (permalink)
allumts's Avatar
Member: 1564612
No, you must buy hde tool.(just User and Password).
in you Cm2 can activate HUA where not include HDE.
Page generated in 0.40279 seconds with 7 queries
