12-02-2017, 14:54 | #17 (permalink) |
Product Supporter Join Date: May 2014 Location: IRAN
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Warning -HDE FLASHER allows to flash any file into phone, it is not being validated by our software or by phone - be very careful what you write into your device! -Phone must be charged up before any kind of flashing otherwise it might go dead |
12-02-2017, 14:57 | #18 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Method 1: This repair method is safest, therefore you should try it first!!! WARNING: DO NOT USE FACTORY FIRMWARES FROM OUR SUPPORT AREA FOR METHOD 1 This step requires original full stock rom file of phone that was in it when it was purchased or before it got bricked, then you have highest chance to revive your phone. Manual1 : Write compatible UPDATE.APP file in fastboot with standard tab |
12-02-2017, 14:59 | #19 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Manual2 After performing steps in guide your phone should boot up Then you need to repeat flashing, but now in upgrade mode This step is necessary to fix incorrect internal storage size after flashing in fastboot NOTE: (If you get error during flashing means firmware you are using is not full stock rom or it isn't original firmware that was in phone when it came out or before it got broken) If method 1 does not help, then may use method 2 |
12-02-2017, 15:04 | #20 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Method 2: This repair method now became safer with possibility not to delete NV and OEM info. If these secure zones were not damaged earlier, using this method with these options checked will not delete IMEI, SN and such. [COLOR="Yellow"]Step 1 Start device repair with factory firmware flash (Can use any factory firmware for any model version - NXT-AL10 factory firmware fits all NXT-xxxx versions etc., same for others) IMPORTNT: Factory firmware files available on our support area. "Factory_Firmwares" & "Factory_Firmwares_with_Testpoint" folders Step 2 After performing phone repair with factory image it should boot up. All text on device may be in Chinese language! Then do flashing in upgrade mode (this time use exact stock firmware UPDATE.APP file of your phone) You can also do an upgrade from SD Card - it's same. If after Factory firmware flashing you are not allowed to do update in Upgrade mode then repeat METHOD 1! Phone numbers REPAIR If your phone is missing IMEI/SN or had selected to delete NV and OEM info when using repair Method 2, or other device info, you can repair and restore them to originals with HDE TOOL You may also need to restore or change for decustomization country and vendor (service available on HDE TOOL), for example vendor value: hw and country value: eu Last edited by Hua Supporter; 12-02-2017 at 15:21. |
12-02-2017, 15:33 | #21 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Flash bricked Huawei phones in qualcomm 9008 mode Huawei Qualcomm phone repair when only QDLoader 9008 port visible -Open HDE FLASHER -Select factory firmware/Board Software File and press "Open" -Check 9008 Port on device manager and install driver(some phone need connect test point) -Press Update -Wait till flashing completes, you will see a message pop up to finish update proccess you must connect the device in upgrade mode and update it. -Complete repair by flashing phone's original full stock rom firmware in upgrade mode Connect phone to PC while in upgrade mode (mode entered by holding both volume buttons and power button usually). -Select Full stock rom by same procedure like in old step Press Update and wait for flash to end to complete phone repair. |
12-02-2017, 15:35 | #22 (permalink) |
Member: 2179353 Status: Offline Thanks Meter: 17,022 | Flash bricked Huawei phones in hisilicon Huawei 1.0 mode (VID_12D1&PID_3650) Huawei hisilicon phone repair when only Huawei 1.0 (VID_12D1&PID_3650) port visible -Open HDE FLASHER -Select factory firmware/Board Software File and press "Open" -Check huawei 1.0 Port on device manager and install driver(some phone need connect test point) -Press Update -Wait till flashing completes, you will see a message pop up to finish update proccess you must connect the device in upgrade mode and update it. -Complete repair by flashing phone's original full stock rom firmware in upgrade mode Connect phone to PC while in upgrade mode (mode entered by holding both volume buttons and power button usually). -Select Full stock rom by same procedure like in old step Press Update and wait for flash to end to complete phone repair. |
