06-14-2017, 17:57 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Apple Watch S2 42mm Done by iBUS S2 using MFC Dongle Version 2.2 [info] Starting ... [info] Using LOCAL IPSW C:\MFC\iDeviceTools\MFC_Watch2,4_3.2_14V249_n75ap_ restore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch, n75ap, Watch2,4 [info] Extracting BuildManifest from IPSW [data] Product Version: 3.2 [data] Product Build: 14V249 Major: 14 [info] device serial number is FH7XXXXXXXX [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 25554972000000000 [info] Getting ApNonce in recovery mode... [data] xxxxx1D53535B889D85CD6FF3DC65BF6B0B0CDCC812A1F3F55 6C6BA5C4CD3DD [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] XXXXXX7A5FC3EABDC855EAAF97EF80E900XXXXX [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [info] NOTE: Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,4_3.2_14V249_n75ap_restore_42mm/058-43387-281.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n65.RELEASE.im4p... [info] Sending iBEC (681499 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-3406.54.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.t8002.im4p... [info] Sending AppleLogo (8298 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-62085-130.dmg... [info] Sending RestoreRamDisk (28816746 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n75ap.im4p... [info] Sending RestoreDeviceTree (100209 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (11321632 bytes)... [info] Restoring device... [info] Waiting for device... [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 14 [info] Device xxxxxx9f9108e41d31896d292cb02643b6f5ea39 has successfully entered restore mode [info] Hardware Information: [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 25554972229xxxxx [info] ProductionMode: true [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n65.RELEASE.im4p... [info] Extracting applelogo@132~watch.t8002.im4p... [info] Extracting dali-ui.n75.release.im4p... [info] Extracting DeviceTree.n75ap.im4p... [info] Extracting recoverymode@132~watch.t8002.im4p... [info] Extracting iBoot.n65.RELEASE.im4p... [info] Extracting sep-firmware.n75.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0A13FF80 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 06B6CCE0 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] About to send FUD data... [info] Found FUD component 'AOP' [info] Extracting aopfw.im4p... [info] Found FUD component 'RTP' [info] Extracting rtpfw.im4p... [info] Sending FUD data now... [done] Done sending FUD data [info] Updating SE Firmware (59) [info] Fixing up /var (17) [info] Creating system key bag (50) [info] Modifying persistent boot-args (25) [info] Unmounting filesystems (29) [info] Restore Finished [info] Cleaning up... [done] Done |
The Following 2 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
09-19-2017, 06:09 | #13 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1750520 Status: Offline Thanks Meter: 2 | Ok .. successfully ordered and got it very fast from MFCBox dot com via DHL Exp., and today first try on Series 2 SS 42mm, also successfull after 2-3 times trying to establish good connection between iBus and iWatch. Went on Mac System, Simple restore via Recovery mode, it was Demo Watch. Thanks |
09-19-2017, 08:06 | #14 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Thanks for your great feedback , waiting for your Success story post & video Br., | |
