08-09-2017, 19:35 | #1 (permalink) |
Insane Poster Join Date: Sep 2003 Location: Ukraine Age: 45
Member: 38419 Status: Offline Thanks Meter: 4 | Apple Watch S2 42mm problem [info] Starting ... [info] Using LOCAL IPSW C:\MFC\MFC_Watch2,3_3.2_14V249_n74ap_restore_38mm. ipsw [info] using cached version data [info] Found device in Recovery mode [info] Identified device as Apple Watch, n74ap, Watch2,3 [info] Extracting BuildManifest from IPSW [data] Product Version: 3.2 [data] Product Build: 14V249 Major: 14 [info] device serial number is FHLSM041HJLL [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Found ECID 1762659681832230 [info] Getting ApNonce in recovery mode... [data] A608AB0302E866D295005C6B3CB2D330FF8DD3A60AC77C59CD 9E9F2781112EE6 [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] D76815E68AA69A7F4F53BD910A5CD0DA812900D3 [warn] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [info] NOTE: Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [warn] Unable to find BbSkeyId node [info] Sending TSS request... [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch2,3_3.2_14V249_n74ap_restore_38mm/058-43345-281.dmg' [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n64.RELEASE.im4p... [info] Sending iBEC (685595 bytes)... [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-3406.54.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@115~watch.t8002.im4p... [info] Sending AppleLogo (7764 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 058-62085-130.dmg... [info] Sending RestoreRamDisk (28816746 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n74ap.im4p... [info] Sending RestoreDeviceTree (100209 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch2... [info] Sending RestoreKernelCache (11321632 bytes)... [info] Restoring device... [info] Waiting for device... [info] some event ... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 14 [info] Device f1986d7ddfbc174703f9f7cafb5137ca73a6389d has successfully entered restore mode [info] Hardware Information: [info] BoardID: 12 [info] ChipID: 32770 [info] UniqueChipID: 1762659681832230 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49156) [warn] Requesting NOT TO Update Baseband [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n64.RELEASE.im4p... [info] Extracting applelogo@115~watch.t8002.im4p... [info] Extracting dali-ui.n74.release.im4p... [info] Extracting DeviceTree.n74ap.im4p... [info] Extracting recoverymode@115~watch.t8002.im4p... [info] Extracting iBoot.n64.RELEASE.im4p... [info] Extracting sep-firmware.n74.RELEASE.im4p... [info] Sending NORData now... [info] Done sending NORData [info] Sending RootTicket... [done] sending RootTicket [info] Waiting for NAND (28) [info] Checking filesystems (15) [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] FDR 0C80A1F0 got sync message [info] Connecting to FDR client at port 49156 [warn] FDR 0DAF5AE8 got plist message [info] Unmounting filesystems (29) [info] Creating partition map (11) [info] Creating filesystem (12) [info] Sending filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [done] sending filesystem [info] Verifying restore (14) [info] Checking filesystems (15) [info] Mounting filesystems (16) [info] Sending KernelCache... [info] Extracting kernelcache.release.watch2... [done] sending KernelCache [info] Installing kernelcache (27) [info] Flashing firmware (18) [info] Updating gas gauge software (47) [info] Updating Stockholm (55) [info] Verification Error [sett] Log is available in ErrorLog.plist [erro] Unable to successfully restore device [erro] Unable to restore device [info] Failed |
08-09-2017, 20:07 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | That's FUD data problem , so you must use the Version 2.2. https://www.mfcbox.com/downloads/mfc...full-installer |
