01-13-2018, 07:43 | #1 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2798619 Status: Offline Thanks Meter: 1 | Dont dislayed IBUS2&S3 in MFC I have problem with displayed IBUS2&S3 in MFC 2.51 When is all connected, i haven't any information about connection of watchS3 via ibus2 in the MFC. Configuration see below - Win 10 64 - MFC V.2.51 - Dongle is allready connented to server - IBUS2 - iWatch S3 in demo mode - Driver for watch correctly installed i think (in USB tree displayed as Apple watch by Dennis MFC) Dongle must be in normal, or demo mode? Watch must be in the DFU mode? I inted separatly connected dongle and ibus to pc.. Do you have idea, where is a problem? Or do you have any recommended? Thank you for report, BR, Milan |
01-13-2018, 17:40 | #3 (permalink) |
Member: 2798619 Status: Offline Thanks Meter: 1 | Dear Denis, thank you for your support, problem was with iTunes. Pease, one more question. I loking on the instruction manual and on YT, for procedure of flash. I have diference - when I select iMFC/FLASH/RESTORE - haven't window explorer for selecz of firmware file. Firmware file is in iDeviceTools and in new folder "firmware" in the root of MFC. Below is text from Restore asingment. [info] Starting ... [info] Using LATEST available IPSW. [info] using cached version data [info] Found device in Normal mode [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [erro] Can't find major version?![/COLOR] [erro] can't get URL for latest firmware[/COLOR] [info] Failed So if is possible help me, thank you for it. Maybe I will not be annoiyng. Best Regards, Milan |
The Following User Says Thank You to Mituma For This Useful Post: |
01-13-2018, 17:49 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Press Restore and same time holding "Shift" key to select the firmware , thanks https://www.mfcbox.com/manual/#features/88 |
01-16-2018, 10:52 | #8 (permalink) | |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
If don't waste time to get those files, you can buy mfc dongle and that with a lot of useful function eg. read icloud password for activated iDevice etc. Thanks | |
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post: |
