Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iBUS Tools For Apple Watch
Old 08-13-2018, 22:47   #1 (permalink)
Member: 2663920
*FIX* no touch after screen replacement
screen repair went as normal but had to reconnect old bad screen to reset so it would open up to pair with new screen. that went normally but after connect new screen touch not work. my solution is to look at it under microscope and see if there are any cracked contacts on the ZIF and if so, put flux on connector and put tiny amount of solder to re bridge it to fix. hope this help
Old 08-14-2018, 03:11   #2 (permalink)
Member: 2516243
Are you replace nfc on screen old to new
Old 08-14-2018, 16:17   #3 (permalink)
Member: 2663920
no i didnt but for s2 it is not need right?
Old 08-14-2018, 18:24   #4 (permalink)
Member: 2777439
Thanks Meter: 16
Apple Pay will not work then.
Old 08-14-2018, 23:12   #5 (permalink)
Member: 2663920
how do I transfer it? seems to be spot welded on or something.
Old 08-15-2018, 16:35   #6 (permalink)
Member: 2516243
[QUOTE=echow2001;13268695]no i didnt but for s2 it is not need right?[/QUOTE
Nfc on screen aw seri 2 , seri 3 is important. When you are reset aw . You are need nfc of screen old is active AW with iphone
Old 08-15-2018, 17:15   #7 (permalink)
Crazy Poster
Member: 2466640
Thanks Meter: 18
Use a chisel-type blade (like Xacto #17) to remove the module. Then you can reattach it with Z-tape. If Z-tape is not available (you can get it from e.g. Adafruit) use conductive ink on the two bumps and then superglue for strength. The second method is more fiddly.
The two solder points underneath the module are NFC antenna connections.
Page generated in 0.16548 seconds with 8 queries
